![]() Drives: '17 1ss m6 Join Date: May 2018
Using a non dexos oil?
The car is cammed, so I'm not worried about maintaining a warranty. I'd like to run a thicker oil(5w-40) since the car sees a lot of hard driving and autocross. I'm having a hard time finding this weight that is also dexos certified locally. Any reason I can run a non dexos oil?
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
I wouldn't there are other factors involved
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
You can get Dexos 2 5w-40 at Wal-Mart or Napa, is that local enough
I must have missed it, I didnt see it at my store. I'll check again.
BAMF SS
I wouldn't hesitate running non-dexos 2 oil, as long as I knew it wasnt some cheap paraffin filled condensate oil. The dexos2 rating is kind of a gimmick... companies have to regularly pay to have that logo on their jug. But the purpose of it, is to make sure the oil life monitor on your car is accurate. If you use an inferior oil, the oil will degrade faster obviously.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
^What he said...if you are changing oil every 3k or less(which you should be in a cam car anyway) then it does not matter. Just put a quality 5-40 in it and change it regularly.
#7 |
Retired from Car mfrs....
As said above it's a marketing tool. They just want to make sure you use good, correct spec oil. If you think about it, GM does not own a refinery, nor check the oil on warranty via Blackstone or an oil analyst service, warranty costs at the dealership don't allow that expense. I.e. GM won't cover the cost of a dealer trying to figure out if your oil was dexos by sending away a sample.
#8 |
I would not go as far to say it was a "scam". GM does not want na in and out west Texas discount oil change place buying low cost bunker oil and putting it in the cars for their $39 oil change special.
I don't know enough about dexos to know if GM is charging a royalty. Maybe, is it a few cents a quart? maybe. Alls I know is Joe Average pays $50,000 for an expensive XYZ and wants the cheapest longest drain interval oil (note I did not say lasting or working) possible that will pour into the motor.... that is what Dexos IMO is trying to stop.
#9 |
I dont mind changing every 3k at all. I put Mobil 1 0-w40 European car blend in the car today, and I plan to change it at 3k miles. I log oil pressure and temperature when I run autox, so if I see anything concerning, I'll report back.
#10 | |
SABIO
#11 | |
BAMF SS
if GM was genuinely JUST concerned about the quality of oil, it would just be an initial fee, and that fee would cover the testing of said oil wanting to be "DEXOS certified."
#12 |
![]() Drives: 2017 1LE Join Date: Nov 2017
I asked black stone if they could tell what oil I had. They said no. Not EVEN if I was DINO or SYN.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
#13 |
Too a point all oil isn't the same but needing something with DEXOS on the label? Come on...any full Syn 5W-30 will be more than enough.
#14 |
![]() Drives: 2018 Camaro 1SS Join Date: Jun 2018
you wont find 5w40 in Dexo label. 5w40 is pretty much diesel oils in market. You are better off pick M1 0w40 instead from Walmart. Cheap and good.
