![]() Drives: 2016 camaro 1ss Join Date: May 2017
Gains from ported MSD & 2 inch headers?
Last year in December I did a heads/Cam package on my car I retained my 1 3/4 headers and non ported MSD. Well now I’m trying to get a good idea of what gains or loss I should expect from switching to Texas speed 2 inch headers and a ported msd. If anybody has some input it is very much appreciated, thank you.
Pray has a pretty impressive dyno of ported stock to ported MSD, I would not expect too much from 1/8 header change and stock cubes but who knows? I had my own ported TB, I went to a Katec 103 mm TB. IMO it is more of a tuner issue and each car is a little different. I never dynoed at all so only have SOTP evaluation. IMO the MSD and 103 TB was worth 5 to 10 on the top with no noticeable sag in the midrange on E85. I did the heads, cam and supercharger all at the same time so I can't tell you what a ported MSD did with just heads and cam.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
1 3/4" are too small. Ported MSD is probably worth 10-15rw over non ported. It picks up tq as well and helps extend the top end.
oh sorry my bad I thought he had 1 and 7/8. Yeah 1 and 3/4 and these are probably short tubes too? will be too small and too short for NA HP on the top end...
#7 |
I think it is hard to say, normally on a small block you won't see much gain. But this engine seems to break all the rules of thumb, so I'd say 8 to 16 HP all above 5000 RPM, with 12 HP being the most probable.
