Old 06-21-2018, 12:40 AM   #1
meSSohappy
meSSohappy's Avatar
Drives: 2018 ZL1 A10
2018 ZL1 pinch points
Hey all
I’ll be damned if I can find the pinch points to use my ZL1 addons jack pad! Is it me or are they hidden under the rockers?
HELP
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
meSSohappy is offline   Reply With Quote
Old 06-21-2018, 01:54 AM   #2
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
There are some cutouts in the rockers
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 06-21-2018, 10:12 PM   #3
Pwiegand
Pwiegand's Avatar
Drives: 2018 ZL1 in sweet hyper blue
Yep, you’ll have to feel for them in the rocker cutouts. There are three. One forward one aft and one about a foot behind the one nearest the front wheel. If you jack on that one you will, eventually, lift both wheels. Check the rest of the forum for jack points and pinch weld “puck/plate” set ups. If you can’t find em let me know and I’ll add some links.
Pwiegand is offline   Reply With Quote
Old 06-22-2018, 10:38 AM   #4
wlsmoku
wlsmoku is offline   Reply With Quote
Old 06-22-2018, 11:04 AM   #5
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Pinch Points
Here they are. You can see the "cutouts" very easily. Just attach the ZL1 Addons to the vertical piece of sheet metal in the cutout and you are good to go.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 06-22-2018, 01:03 PM   #6
greaser2
greaser2's Avatar
Drives: 2017 A10 ZL1 KG
Funny ur showing the correct lift point for lifting while the car is being lifted in the wrong points.
greaser2 is offline   Reply With Quote
Old 06-22-2018, 02:30 PM   #7
Larrio Andretti
Drives: Really Fast
Hes just trying to show the rocker cutouts.
THIS SPACE FOR RENT
Larrio Andretti is offline   Reply With Quote
Old 06-22-2018, 02:41 PM   #8
unavailablezl1
They ARE the correct place to lift. Ask anyone that knows. BUT BUT, you can only do it with a 4 point lift.
This was at the Chevy Dealer.
Current ride
Past Rides
Old 06-22-2018, 03:03 PM   #9
kaamacat
Drives: 2018 ZL1/1LE Red
The last pic (left front)... is it the pic playing tricks, or, is that pinch weld section totally bent upwards to almost flat?
BobR
2018 ZL1 1LE (Red) - New Dec 2017
2015 ViperGT (Gunmetal w/Red stripes)
2013 ZR1 Anniversary
2014 ZL1 - BrightYellow, 6sp
2011 Porsche GT3RS - White w/red graphics
2009 Porsche C2S
2001 Ferrari 360
kaamacat is offline   Reply With Quote
Old 06-22-2018, 03:14 PM   #10
unavailablezl1
Yes, it is playing tricks. It is close, but the lift touched nothing but what it is supposed to. Nothing crushed. I got my face right up to every lift point. I took many more pics. These are just to satisfy the OP.
I even got the top Service Manager of the dealership involved when I thought it was being lifted wrong. At first he thought it was too. This car had just come out and not to many on a lift. He got with the body shop manager and personally took it to the body shop to fully check alignment of the body, I think it uses lasers. The care was Perfect!! He even gave me the printed report of body alignment. I love this dealership.
So I got a bonus out of it by getting it checked, knowing everything was ok even before they put it on the lift.
Current ride
Past Rides
Old 06-22-2018, 05:27 PM   #11
itsadryheat79
itsadryheat79's Avatar
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z
Send a message via Yahoo to itsadryheat79
I use the ZL1 add on Jack pad to attach to the pinch wells in the cutout under the rockers.
I can lift it from the center pinch well to lift both the right and left side at the same time. Makes changing tires a snap.
For oil changes I use the front pinch well areas to lift either side and use a "Race Ramp" tire crib under both front wheels. This keeps it plenty lifted and safe while crawling around underneath.
- Buttons and Skulls -
miss my annimated signature.
itsadryheat79 is offline   Reply With Quote
Old 06-22-2018, 05:59 PM   #12
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
I can tell you one thing, that aluminum front sub-frame is really flimsy. Thought I read you could lift the front of the car... from the center under the engine, it started to give on me when I used my lift jack, while up on my four post.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 06-22-2018, 07:20 PM   #13
greaser2
greaser2's Avatar
And we all know chevy dealers know what they are doing. Ur not supposed to lift the car on the aluminum suspension component that they did.
Old 06-22-2018, 08:24 PM   #14
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
Agreed......I don't care if the dealer, bodyshop and owners manual say its ok.......lifting on the aluminum subframe is NOT ok.
Stefano is offline   Reply With Quote
