Old 06-19-2018, 10:13 PM   #1
Getinthur
Drives: 2017 ZL1
Weapon-X Ice Box install
I bought the Weapon-X ice box to go with my heat exchangers, they came in today but they didn't supply any directions. Has anyone installed this set up before? I reached out by phone and email to ask some questions but I haven't gotten a response yet. I have the following questions:
1) The intercooler pump has a connector on it, why? where does it connect to? (see pic)
2) Where should the pump be mounted?
3) Where in the intercooler system should the tank be tied into?
Getinthur is offline   Reply With Quote
Old 06-19-2018, 10:38 PM   #2
kttxz06
kttxz06's Avatar
Drives: '18 Zl1. '18 GT350.
I was going to order one, but wasn't going to re-route all of the electronics in the trunk. So, I went with the Cordes 2.5 front mount tank.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
kttxz06 is offline   Reply With Quote
Old 06-19-2018, 11:48 PM   #3
chicagosam
chicagosam's Avatar
Drives: 2017 BLACK ZL1 A10
Do you have pics of the Cordes tank installed?
Please post.
'17 Mosaic ZL1 Katech TB, Plugs/Wires, Rotofab Oiled,+18% Lower, 2" Headers, Cat Delete, 93 Tune, Mobil 1, IPA FF04, 315/30/20 r888r, 664hp/693tq (93), 702hp/727tq (100 oct)
chicagosam is offline   Reply With Quote
Old 06-19-2018, 11:50 PM   #4
kttxz06
kttxz06's Avatar
Please post.
I don't, but Joel will once he installs it. He bought my blower set up and the tank was included. I never installed it. It's 2.5 gallons and that is plenty and considering it's a front mount with no special instructions, to me, that's the ice tank to go with. Someone needs to hit up Aldo Welds and have him start building his tanks for the 6th Gen.
Old 06-20-2018, 10:49 AM   #5
scooter k
Drives: ex-wife's car
I have one and installed it. I mounted my pump on the bumper bar. The outlet from the tank has grid welded over the hole to keep ice from going down into the pump. I moved the electronics to the sides. I had to make mount for the fuse block.
scooter k is offline   Reply With Quote
Old 06-20-2018, 11:23 AM   #6
IneedAZ
IneedAZ's Avatar
Where did you order the Cordes from?
Old 06-20-2018, 11:39 AM   #7
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
The connector is the pump's power supply. Did it come with the female connector, and fused wiring? Pump should be close to the tank as possible (depending on pump). Does this mount in trunk? Pick of a tank built 6.75 gallons rule 2000 in tank.
Turbo_RORO is offline   Reply With Quote
Old 06-20-2018, 06:09 PM   #8
kttxz06
kttxz06's Avatar
http://cordesperformanceracing.com/
Hit up Joe at Cordes. Or Weapon X sells them.
Old 06-20-2018, 06:35 PM   #9
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Anyone have installation instructions for the cordes one?
Old 06-20-2018, 07:03 PM   #10
Getinthur
Drives: 2017 ZL1
Scooter,
Did you power pump with a 40A relay? What did you tap into for power? Where did you run your hoses to?
Old 06-20-2018, 07:14 PM   #11
IneedAZ
IneedAZ's Avatar
Thanks
Old 06-20-2018, 07:39 PM   #12
kttxz06
kttxz06's Avatar
No, but it looks pretty simple. You'll need to cut a bigger whole in the beauty plate for the cap to fit through or they'll supply you with one for like $100 extra. I just liked it cus you don't have to mess with any electronics in the rear trunk. Plus, 2.5 gallons does just fine anyways. At the end of the day, it gives you more flow. Loading up a 5 gallon ice tank is only good for one or two passes anyways. The Cordes hooks right up to your stock system or it works with Weapon X's HX system. Plus it's a front mount. As mentioned, once we take off all of my blower stuff and install it on Joel's, I'll make sure to take some pics of the install.
Old 06-20-2018, 07:59 PM   #13
scooter k
Originally Posted by Getinthur View Post
Scooter,
I used a relay yes. Since the connector removes from the pump I cut that other connector off and soldered wires with heat shrink tubing on there. I got the new style add a circuit fuse tap. Fuse tap has spots for two fuses, one for the original circuit and new circuit. I believe I used the heated steering wheel fuse, in the trunk fuse block. It was hot with the ign on. You run the hoses down the ground effects. You run the new pump in parallel with the factory pump. So out of the heat exchanger in the front, over top of the RF wheel well down the ground effect, and over the rear suspension. That's your return hose to the reservoir. The other hose would go down the left ground effects and to the supercharger. All the other hoses will stay in their original locations. If you notice the right small heat exchanger is for the engine cooling system and the left one is for the supercharger. Send me your email because I think I have the instructions I can email you.
Old 06-20-2018, 08:52 PM   #14
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Does the front bumper have to come off?
