Old 06-19-2018, 10:37 AM   #1
Torquem
Bannable
Torquem's Avatar
Drives: 2017 Camaro ZL1
Possible issues with Rotofab and/or TM ported throttke body
I installed the rotofab dry CAI at the same time that I installed a TM throttle body. Ever since then it feels like the car is breaking up a bit at WOT. Hard to explain the feeling. Doesn't feel like it is pulling very hard. Almost feels like not enough fuel or spark. Easiest way to explain how it feels is like driving into a really strong headwind. Any thoughts?
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic
Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's
Torquem is offline   Reply With Quote
Old 06-19-2018, 10:45 AM   #2
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
Have a tuner do a data log during a WOT and see results. This car runs extremely rich from the factory, so I doubt you are running out of fuel, but really only one way to know for sure.
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 06-19-2018, 10:46 AM   #3
Lethal Z
American Gearhead!!
Lethal Z's Avatar
Drives: ZL1 1LE/GT350/Ford RS/Gen 2 Raptor
If you are not getting a check engine light, chances are you installed everything correctly. Recheck all connections, if everything is tight, I would reinstall the factory throttle body and see if the issue persists.
Lethal Z is offline   Reply With Quote
Old 06-19-2018, 11:22 AM   #4
Zl1steve
Drives: Zl1
How many miles? I had the same problem and mine was the plug wires. The stock wires are ok but have a ton resistance. Firecore wires are the best there is period. You may need to drive car more so it can learn the correct air fuel strategy. Mine missing around 5500 and up and switching out wires cured mine. I have headers tune pulley and ported tb and rotofab. Car has ran 10.82@ 133.8 on stock tires.
Zl1steve is offline   Reply With Quote
Old 06-19-2018, 11:40 AM   #5
hashtag
hashtag's Avatar
Drives: 2018 ZL1 A10/2018 GT350R #JR603
Part number for the Firecore Wires if possible. I searched & was not able to find it. Would like to get a set.
2018GT350R+2018 ZL1 "Red Hot" A10 w/ PDR, Nav, Carbon Fiber Hood insert, Carbon Fiber Dash Insert, Carbon Fiber Fuel Dior & Sun Roof. T/M T-Body, Roto Fab & Borla S Type.
hashtag is offline   Reply With Quote
Old 06-19-2018, 01:07 PM   #6
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
Smile
If you dont mind me asking what your 60ft time was on that? That MPH should be deep into the 10's... just curious.
2018ZL1 is offline   Reply With Quote
Old 06-19-2018, 03:14 PM   #7
Zl1steve
Drives: Zl1
1.86. Best 1/8 mile mph 105.84. With drag radials it should go 10.50 or so. And it was a 10.88 not 10.82.
Old 06-19-2018, 03:20 PM   #8
ReefBlueCoupe
ReefBlueCoupe's Avatar
Drives: A few of each
Go back to stock. See if the problem still exists. If not, add each separately and see if you notice what you are describing. If you do notice what you are describing with either installed seperately, contact the corresponding vendor with your thoughts on the matter.
'18 MBM ZL1 1LE
ReefBlueCoupe is offline   Reply With Quote
Old 06-19-2018, 03:21 PM   #9
Zl1steve
Drives: Zl1
Here are 2 passes.
Old 06-19-2018, 03:22 PM   #10
Zl1steve
Drives: Zl1
Call up Carlisle racing they have them.
Old 06-19-2018, 04:08 PM   #11
2018ZL1
2018ZL1's Avatar
Thanks! didnt mean to Hijack this post!
Old 06-19-2018, 05:03 PM   #12
conradsteph
conradsteph's Avatar
Drives: 2017 ZL1 Vert Arctic Blue
Try disconnecting the negative terminal in the trunk for a couple of minutes then reconnect. A few months after my install during a WOT pull, I had a Check Engine Light pop up with significantly reduced power. Discussed it with my installer and he mentioned that occasionally the ported throttle body can cause the issue. Battery disconnect reset everything and all my horses and torque are back.
conradsteph is offline   Reply With Quote
Old 06-19-2018, 05:05 PM   #13
hashtag
hashtag's Avatar
Word. Appreciate it
Old 06-19-2018, 06:13 PM   #14
biscuit60140
I'm actually in a similar boat with the OP. My car feels like it almost lunges or stutters under like 3/4 throttle but driving normal and even full throttle seem okay. I've double checked everything and it looks good. All I can think is maybe it needs more time to learn how to deal with the new parts.
biscuit60140 is offline   Reply With Quote
