![]() Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
Vented seat performance
How much air flow is typical for the vented seats set on high? I'm suprised that I can barely feel any airflow.
![]() Drives: 2018 2SS Join Date: Aug 2017
It's not that powerful. The fan is very small but I think it works fine, at least for me.
Certainly not a vacuum cleaner in reverse, but sufficient. We had about 90 degrees outside the other day, and I could definitely feel the cool airflow (at max level) right after getting into the car from the heat.
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
It basically just has a few computer chassis cooling fans under the seat cushion. You’ll get airflow but it’s not gonna blow up Marilyn Monroe’s skirt.
![]() Drives: 2017 Camaro 2SS, A8 Join Date: Aug 2017
It keeps you from sweating which is nice with leather.
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Designed to cool the seat, not your ass!
#7 |
I barely feel it. Anyone ever attempt a fan upgrade?
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro 50th anniversary edition Join Date: May 2017
+1.
You shouldn’t feel an air draft. I find it very comfortable.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
#9 |
![]() Drives: 2016 Summit White Camaro SS (2SS) Join Date: Oct 2016
#10 |
BAMF SS
Wear basketball shorts and go commando.
#11 |
![]() ![]() Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28 Join Date: Jun 2018
Technically, the fans don’t “cool.” They just move air from the surrounding area toward your rear end. The cooling effect is similar to wind chill causing temperatures to feel cooler (or a ceiling fan blowing on you during summer), but in this case you can only count on feeling a few degrees’ worth of difference.
#12 | |
#13 |
![]() Drives: 2018 ZL1 1LE Join Date: Mar 2018
The first time I turned it on I felt the seat actually get cooler. Since then I haven’t felt that same sensation, but it does prevent the seat from getting warmer on a hot day.
2018 Chevy Camaro ZL1-1LE
2015 Silverado 2500HD 1999 Jeep Cherokee Sport 1998 Dodge Viper GTS 1972 Pontiac GTO 1963 Chevy C10 short bed, T5, 350, lowered |
#14 |
You guys do turn the A/C on as well, right? Otherwise the seat fans will shift warm air around, which doesn't help much. I do feel the air movement, and the fans are actually quite audible.
