Old 06-15-2018, 02:32 PM   #1
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Source for stock ZL1 (1LE) brake pads?
Any sources apart from the dealer on the OEM brake pads? I'm actually quite fond of them on track.
seanblurr is offline   Reply With Quote
Old 06-15-2018, 02:53 PM   #2
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Hate to give away my secret, but, for both the J6M (SS 1LE) and J6H (ZL1) pads, they have shown up (dirt) cheap at times on the forums from guys wanting to go with low dust pads. Same for the tires, both G3's and G3R's with guys wanting a more street friendly option.
I have been a hoarder, and will continue to be, for pads and tires. Hint, anyone reading this that does not want their stock ZL1 brake pads or Goodyear G3R's anymore, send me a PM or email...you can give SEANBLURR second dibs (LOL)!
RUQWIKR is offline   Reply With Quote
Old 06-15-2018, 03:01 PM   #3
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
GM Parts direct. $220 for front pads, $80 for rear. Seriously.
Provoste is offline   Reply With Quote
Old 06-15-2018, 03:07 PM   #4
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
GM PN DELCO
23399101 171-1192 Front
89047744 171-0882 Rear
If you have a Delco distributor buddy, they are a good percentage less from them, same box, same parts.
Old 06-15-2018, 03:52 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
cheapest GM part
GM parts online
etc etc
Old 06-15-2018, 03:55 PM   #6
Stephen12ZL1
Drives: '21 ZLE A10
I see most places $228 front & $83 rear
Old 06-15-2018, 04:52 PM   #7
dchesrown
Drives: ZL1-1LE
I just purchased 3 sets 150 front and rear shipped.
dchesrown is offline   Reply With Quote
Old 06-15-2018, 04:56 PM   #8
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
How are these pads so cheap? Last I checked, the Brembo/Ferodo's were in the $400's. Even more of a reason to continue to use them over my race pads.
Old 06-15-2018, 05:00 PM   #9
dchesrown
Drives: ZL1-1LE
Fleabay. I have already received my first set new in the box. Ordered 2 more fronts one rear. Item # 162475914479 fronts. Tell him you want my same deal make offer 100 fronts 50 rear. ( Separate item # same seller rears)
Old 06-15-2018, 08:19 PM   #10
Stephen12ZL1
Drives: '21 ZLE A10
The stock pads are just OK. Step up to G-LOC pads for great brake torque and decent longevity. $676 front & rear set but well worth it. JPSS online sells them.
Old 06-15-2018, 08:39 PM   #11
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I would say the stock pads are far beyond just ok. They have provided nearly everything I've asked and will probably double the life of the rotors compared to any real race pad. This is not to say that I won't finally start using a race pad again, but at this time I see no reason.
I've used G-Loc and currently have a set of Hawk DTC70/60's. Sure, initial bite is much better but race pads destroyed my calipers. Caliper temps were nearly 200 degrees hotter with race pads. Melted all the piston seals and discolored the calipers. Stock pads don't get nearly that hot, so my calipers are holding strong.
I'm going to try to keep the stock pads in as long as I can, but I have no hesitation going back to race pads if need be. If I can say this humbly, I'm no slouch behind the wheel either. So these pads can't be that bad...
Old 06-15-2018, 10:01 PM   #12
Provoste
Provoste's Avatar
Agreed.
Old 06-15-2018, 11:09 PM   #13
Stephen12ZL1
Drives: '21 ZLE A10
My definition of OK wasn't clear. Maybe the inclusion of the word "just" turned the tone to "meh, OK". For stockers they are acceptable considering the performance of the ZL1. No doubt DTC 70/60 eat rotors like potato chips, and I can believe the seals could deteriorate quickly using these. I prefer the brake torque of the G-LOC pads as they are more confidence inspiring at 160mph compared to stockers. My calipers have thus far been flawless with 2K track miles at VIR. Personal preference prevails in this discussion.
Old 06-15-2018, 11:45 PM   #14
DANACO
DANACO's Avatar
Drives: 18 ZL1
Does anyone know the difference between the 1Le and ZL1 pads, are they not the same calipers on each car ?
DANACO is offline   Reply With Quote
