Old 06-14-2018, 06:43 PM   #1
speedup
speedup's Avatar
Drives: 2017 2SS Convertible
Charging pad upgrade works perfect! iPhone X charging in 2017
For anyone interested - i posted a message a couple weeks ago about installing the updated charging pad in our 2016s and 2017s.
The part is 84526978, it is a direct replacement part, that fits perfectly in my 2017. A harness adapter is needed, but it is included with the part.
To install: remove center console and shift knob (4 10mm bolts up front behind knee pads, 2 10mm bolts behind covers located low in the back seat area, need to move seats all the way forward to get to them)
I did not even have to remove the console, I just sat in the back and lifted it up from there. 4 torx head screws hold the pad in.
GET IT, works perfect!
2017 2SS, Hyper Blue, 8sp, NPP, MRC
speedup is offline   Reply With Quote
Old 06-14-2018, 06:50 PM   #2
Ruebernard
Ruebernard's Avatar
Drives: 2023 Radiant Red Tintcoat 2SS
That's awesome! Thank you for being the pioneer!
If it were more fun, it would be illegal!
Ruebernard is offline   Reply With Quote
Old 06-14-2018, 06:55 PM   #3
speedup
speedup's Avatar
Install was so easy too, literally took 20 minutes, and I took my time.
When removing the knee pads, use a trim tool at the bottom of the pad, they lift straight up.
The shift knob is just pushed on, no screws holding it on, just lift straight up. I did not remove the boot from the knob.
The console does not need to be removed, I just got it all loose and lifted from the back.
super easy!
Old 06-14-2018, 08:07 PM   #4
98_Camaro
98_Camaro's Avatar
Drives: 2016 2SS Coupe
Any pictures of the upgraded setup? Seems like a cheap, reasonable upgrade.
Gone but not forgotten:
1998 Bright Purple Metallic Camaro
2012 Carbon Flash Metallic 2SS Convertible
2016 Summit White 2SS Coupe M6, NPP, & MRC
Now Driving:
2016 Torch Red Corvette 2LT, NPP, MRC
98_Camaro is offline   Reply With Quote
Old 06-14-2018, 08:11 PM   #5
speedup
speedup's Avatar
I was going to take pics, but it was so easy there really wasnt a need.
The pad is almost identical to the gen 1 pad. Everything fits perfectly, no modifications needed at all (other than the included harness that is plug and play)
I got mine for $75 shipped from gmpartsgiant.com
Old 06-14-2018, 08:27 PM   #6
USRobo
USRobo's Avatar
Drives: 2004 Corvette / 2017 2SS Camaro
What phone will fit in it? Iphone X, Galaxy Note 8, etc.
You really need pictures.
super easy!
USRobo is offline   Reply With Quote
Old 06-14-2018, 09:07 PM   #7
guitarman8373
guitarman8373's Avatar
Drives: 2016 2SS Camaro fully loaded.
Can we see pics of it now at least? And of it compared side by side to the old one?
guitarman8373 is offline   Reply With Quote
Old 06-14-2018, 09:15 PM   #8
speedup
speedup's Avatar
damn, wish I had taken pics now... only pic I have is of the screen showing the charging bolt.
Old 06-14-2018, 09:30 PM   #9
speedup
speedup's Avatar
took a few - hope it helps, top pic is the new one installed, bottom is old one
Old 06-15-2018, 09:35 AM   #10
ICTsccaCamaro
Drives: 2018 ZL1 1LE
Is the X really small enough to fit in the charger spot? Regardless of charger my note 8 isn't fitting in the spot.
ICTsccaCamaro is offline   Reply With Quote
Old 06-15-2018, 09:40 AM   #11
speedup
speedup's Avatar
iphone x lays flat without the case. I have an otterbox symmetry case that does not let it sit perfectly flat, but it still charges like this, even with case on
Old 06-15-2018, 02:02 PM   #12
john94si
john94si's Avatar
Drives: 17 2ss vert
So this is the piece we need to upgrade? https://www.gmpartsdirect.com/oem-pa...e-pkg-84526978
john94si is offline   Reply With Quote
Old 06-15-2018, 02:04 PM   #13
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
obviously this is for the people who dont plug in for android auto or carplay. So this is not a feature i could utilize so I haven't.
But my suggestion for those who do find this as a useful feature, to get off the idea of making this charging pad horizontal to fit inside the tiny length and width of the cubby area. You can charge while the phone is vertical or learning on an angle. This gives you much more flexibility in phone sizes without really impacting convenience (it's almost definitely more convenient than laying flat).
I made a vertical pocket out of some fiberglass for my phone. Adding wireless charging to the pocket would be trivial. Then it would fit any phone without risking it falling out.
Old 06-15-2018, 02:11 PM   #14
speedup
speedup's Avatar
correct - comes with charging pad, and harness adapter that you will need.
