Old 06-13-2018, 01:47 PM   #1
TRich2SS
Drives: 2016 Camaro 2SS Summit White
Changing stock HID's
So my passenger side HID bulb appears to be out. I was wondering if any of you have any experience changing the HID bulb, specifically on the passenger side. It looks really tight and I was curious if it necessitated taking off the bumper or anything else of that nature. Any info would be greatly appreciated.
TRich2SS is offline   Reply With Quote
Old 06-13-2018, 01:49 PM   #2
Jeb114
Jeb114's Avatar
Drives: 2021 300
Should be under warranty.
Jeb114 is offline   Reply With Quote
Old 06-13-2018, 06:42 PM   #3
17_50
Not A Loser
17_50's Avatar
Drives: 2017 H50 1AK67 MN6
It's definitely a bit early for the HID bulb to have failed, I would recommend the warranty route as well. The bulb may be fine, but the ballast powering it may have failed.
17_50 is offline   Reply With Quote
Old 06-13-2018, 07:15 PM   #4
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
I swapped my ZL1 bulbs for 1 color temp cooler (to better match the LEDs). For whatever reason the together passenger side was a breeze, and after removing the air filter the driver side was a royal PITA. The damn seat for the bulb was just cut poorly, and the teeth on the new bulb did NOT want to click in properly. Took me hours for that one side and finally resorted to a large set of dykes to assist [insert joke here].
ninetres is offline   Reply With Quote
Old 06-15-2018, 10:32 AM   #5
SummitWhiteShark
Drives: 2017 Camaro SS Summit White
Just buy osram cbi I have them and it’s amazing
SummitWhiteShark is offline   Reply With Quote
Old 06-15-2018, 02:45 PM   #6
TRich2SS
Thanks everyone I guess for the sake of $$ I will try the warranty option first. If not, I might take ur route Summit and go aftermarket.
Old 06-15-2018, 02:55 PM   #7
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Weird failure, last 2 cars were HID, over 10 years, same bulbs and ballasts. Def. a "bathtub" failure.
ing for grip.
http://www.motorsportsne.com/
