estimated rwhp numbers
hey there i have ported heads, tsp vvt 2 cam, long tube headers, Cold air intake with a full custom exhaust (catless) what numbers do you think i will get with this setup not looking for a straight line car building it primarily for road course.....
![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS/1LE Join Date: Sep 2016
It really all depends on the dyno. If you don't have a baseline dyno, chasing a number is pointless. Depending on the dyno, you may see anywhere between 420rwhp and 550rwhp.
mustang dyno numbers 478hp/462ftlb then i was told their dyno reads 13% lower numbers but im glad with the numbers i have now
#5 | |
Same dyno for baseline and the 478/462 run? |
i was thinkin that also and no not done on the same dyno the 401 baseline was done on a dynojet
#7 |
#8 |
#9 |
![]() ![]() ![]() Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
I would imagine a gain of ~ 100 to 110 rwhp. Add E85 then maybe 125 to 135+
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
#10 |
![]() Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
The real question is, how can you have heads and cam and not be tuned and ran your car on a dyno. I think what your trying to do is find out how much you can make if you had all of those parts. That's my thought.
#11 | |
![]() Drives: Black Join Date: Jan 2017
Imo all you need now is a ported throttle body and intake manifold and you will have derestricted the entire path Guys with similar mods plus the mods I mentioned are in the 550whp+ range |
#12 |
in the process of doing this i ran into medical issues but ill be gettin it
