06-08-2018, 03:58 PM | #1 |
Drives: 2015 1LE Join Date: Oct 2015
Improving Traction?
Does installing rear cradle bushings and new trailing arms actually improve traction on the street? I know it helps with wheel hop but I'm hoping it will give the car some more bite too? Any feedback would be great.
06-08-2018, 04:55 PM | #2 |
Drives: cars Join Date: May 2011
Improved stability and reduced wheelhop, they won't bite anything or anyone.
06-08-2018, 05:20 PM | #3 |
Drives: 2015 Z/22 Join Date: Aug 2015
They most certainly do; after I did mine I could feel a difference when I stepped on it and I only have a little ol' V6, so I suspect the difference would be even more noticeable in a V8.
Edit: maybe I misread the post, but said upgrades will keep the tires on the ground when accelerating by reducing wheel hop as mentioned, so they'll improve traction from a stop
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
06-08-2018, 05:57 PM | #4 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
nope....
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
06-09-2018, 06:39 AM | #5 |
If you are dropping more torque than the tires can handle they will spin. The only tires I have found that I can not break loose smashing the throttle on my while going about 10-20mph are the MP4S. Even regular Pilot Super Sports I can spin thru.
Running 285/35-20 all the way around. |
06-09-2018, 07:18 AM | #6 | |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
06-09-2018, 08:16 AM | #7 |
if I run my DR's on the street at 30 psi they break lose....at the track at 12 psi and a burnout...not so much...
peace. btw - my BFG comp 2's do a good job, especially in the rain...
06-09-2018, 10:35 AM | #8 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Those items will help stabilize the rear. The cradle bushings help the IRS feel as part of the car in turns, not follow the cars in turns. Both really helps in autocross that I do a lot of. As to traction I have every part to reduce wheel hop and I don’t seem to have that issue. Traction though? I run RE71R’s 305/30/19 for autocross, I can only leave the start at 1500 rpm to get could bite. Past that no way.
06-09-2018, 02:18 PM | #9 |
I am talking about when already rolling, not reving up engine and dropping clutch and breaking them loose.
06-09-2018, 03:15 PM | #10 |
06-09-2018, 08:03 PM | #11 |
It is a night and day difference in how the power is put to the ground. IMO yes, it improves every aspect of the handling.
2015 Camaro Z/28 Black
Sold: 2010 Camaro 1SS/RS |
06-09-2018, 09:31 PM | #12 |
We have near identical setups. I have the sport comp 2 on the front and the nitro 555R on the rear. Same tire pressures!
