Old 06-08-2018, 08:12 AM   #1
IneedAZ
IneedAZ's Avatar
Gen6 ZL1 vs 2019 Hellcat, Power increase possibly
Came across this article that mentions a possible HP increase for the Hellcat for the 2019 model year. I have a 2017 ZL1 i ordered Jan 2017 and i Love the car, but it will suck if Hellcat gets a boost in HP and Chevy doesn't respond. We are already lower in HP and the gap might get larger :(
Here is the article:
http://www.autoguide.com/auto-news/2...py-photos.html
Old 06-08-2018, 08:25 AM   #2
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
LOL, Hellcat is a relatively ancient 1 trick pony. More to cars than HP numbers.
I agree GM should respond with HP bumps when they do refreshes, but just because they can and not because the ZL1 becomes less great due to what another manufacturer does you know? I would rather have a ZL1 over a Hellcat even if they gave that thing 1000 HP.
I have never envied a Hellcat owner, but would LOVE to have a ZL1.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 06-08-2018, 09:27 AM   #3
shaffe
Drives: 21 Bronco
I agree I think that GM should increase power with refreshes, that is one thing that bugs me about them. Yes the Camaro is all around the better car but to me, it's once a model hits the lot for the most part that's it they are onto the next one.
Lets keep it simple. ..
Old 06-08-2018, 10:52 AM   #4
Fraxum
Fraxum's Avatar
Here is what I do not understand.
Hellcat - 4450 pounds 707 HP = 6.294 lb/hp (C&D internet weight)
A10 ZL1 - 3915 pounds 650 HP = 6.023 lb/hp (my Z actual weight 1/4 tank)
Why isn't the ZL1 already faster?
A. More ZL1 drive train loss?
B. The builtin ZL1 bog?
C. The bad kitty is underrated?
Old 06-08-2018, 10:54 AM   #5
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
C
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 06-08-2018, 11:24 AM   #6
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
I’ve seen tons of races where they are dead even, or whichever driver gets the hit stays ahead. I haven’t seen a good race where both are bone stock and a HC pulls away. The p/w numbers seem accurate to me. Almost identical.
ninetres is offline   Reply With Quote
Old 06-08-2018, 01:18 PM   #7
Fraxum
Fraxum's Avatar
Originally Posted by bobby35ny View Post
C
I did some quick internet reading on this topic, so you know it's true.
The HP number may be accurate @ 6,000 RPM but there is more power further up. So yea. C.
But for the HC to be even power to weight it needs almost 740 HP which about jives with what the somewhat general consensus of around 750.
But even there the ZL1 and HC are alsmost dead even. Yet HCs are noticeably faster.
So yes some of C. On stock tires HCs and ZL1s are dead even on 60' times. So #2 doesn't seem relevent.
Maybe the HC auto is better than the A10 for good 1/4 times so maybe #1, but instead of drive train loss, maybe too much shifting loss.
Old 06-08-2018, 01:41 PM   #8
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
My boy has a HC 6M, I know the car well. Besides Mass and movement and all that stuff,
I kill him from the dig, 40mph he has the edge on me. I'm sure the A10 will have the edge on him.
That said...
The HC don't have the heavy handed nannies like we do. If you look at some dyno runs, its pretty clear its pushing 725 not 707.
-bobby
Old 06-08-2018, 02:24 PM   #9
newmoon
newmoon's Avatar
Drives: 2019 GT350
The Hellcat needs tires. Trying to harness that kind of power and torque with 275 series all season tires is nearly impossible. Hell I have 285s on my Boss and I can't hook up. The Cat desperately needs a sticky 305 series tire more than a HP increase. Figure out a way to fit 305 rears without having to purchase the Wide-Body option.
2019 GT350 RR
2013 Boss Mustang
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
Old 06-08-2018, 03:12 PM   #10
BlaqWhole
Drives: 2017 Camaro ZL1 A10
The Hellcat is more underrated than any other car I've ever seen. While it is typical to see some ZL1s in the 550-580 RWHP range, most Hellcats with the M6 trans are dynoing at upper 600s to the wheels. And the A8 Hellcats are dynoing in the mid 600s. That is bone stock. Plus a pulley and tune puts them at approx 750 RWHP on 93 octane. So it's a bit of a mismatch. Gotta remember they have a 2.4 twin screw blower to the ZL1's 1.7 roots style blower. And the Hellcat has a very healthy cam vs the ZL1's restrictive cam. All of that plays a part. The extra power of the HC is enough to offset the extra weight and then some. I'd put my money on a Hellcat beating a ZL1 in a road race.
That said...
-bobby
If he is on the stock P-Zero tires then you should have no problem beating him from a dig. If he throws a good set of DRs on or even just a better street tire then I'd give him the advantage. At my track the Hellcats guys are all in the 10.8-11.1 sec range with nothing but a tire and air filter removal.
Old 06-08-2018, 04:08 PM   #11
SpeedIsLife
Drives: Current Camaro-less
There are limitations that are inherent to the LX/LC platform which prevent this. IIRC the widest tire that can fit without going over the limits (IE sticking too far out from the wheel wells) is 295.
Old 06-08-2018, 05:30 PM   #12
BlaqWhole
Oh and I forgot to add that the newer Hellcats will have the option for 725 HP. But I think that is the wide body style. The normal ones will have the same 707. From what I know.
Depending on the tire tho. Since not all tires are the same width even at the same size. I think a few have gotten a 305 on the rear. But 295 does seem to be the norm. Even swapping to a 295 in just a better street tire improves the performance. Those P-Zeros are garbage for real.
Old 06-09-2018, 05:15 AM   #13
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
295's aren't even enough for 500 hp, that's crazy.
Sent from my SM-G955U using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 06-09-2018, 08:32 AM   #14
newmoon
newmoon's Avatar
Drives: 2019 GT350
There are plenty of photos out there with owners running 305s. Dodge might have to change the rim design a bit but 305s will fit. Atleast make it an option.
2019 GT350 RR
2013 Boss Mustang
