![]() Drives: 17 Camaro 2SS Join Date: Jan 2012
Memory Mirrors
I've wondered about this since I got my car about two years ago but always forget to look it up. What is the reasoning behind having the memory side mirrors point to the sky when I get out of my vehicle? I understand the seat going back to allow easier egress, but why do the mirrors have to move at all unless "driver 2" gets in the car someday? Seems like unnecessary wear on the mirror motors.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro 50th anniversary edition Join Date: May 2017
I never noticed that the mirrors are tilting.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS w/2SS A8 Blue Velvet Join Date: Dec 2009
Mine only tilt when I back up to show the lower area that cause a curbing by the wheels and I didn't set that up to do that, the tilt or adjust with my driving settings but never have they tilted upward the sky.
Never grow up, it's a trap!
![]() Drives: 2017 2SS Manual Join Date: Apr 2017
UFO Check to prevent alien abductions?
![]() Drives: 2SS, CT-R, LC500 Join Date: Jan 2018
There is a setting to disable auto tilt of the mirrors
#7 |
![]() Drives: 2016 Procharged M6 Camaro 2SS Join Date: Apr 2018
Sounds like your memory position to exit the car is set to do that. Put the seats/mirrors where you want and save it.
#8 |
![]() Drives: 2017 2SS Summit White Camaro M6 Join Date: Mar 2012
You must have ordered the drone alert option
#9 |
![]() ![]() ![]() ![]() Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
you have the exit programmed to move the mirrors up. Put everything were you want for exit then memory save. I only have my right mirror move down in reverse so I can see the edge of our driveway.
#10 |
![]() Drives: 16 2SS Convertable Join Date: Feb 2018
Set your mirrors with car running in park, when you go to reverse they drop to show you curb placement, standard on 2ss
2SS Convertible A8, NPP, GMPP CAI, Flow tie grill, Mishimoto Oil catch can, Eibach lowering springs.
#11 |
Pg 46??
Reverse Tilt Mirrors If equipped with memory seats, the passenger and/or driver mirror tilts to a preselected position when the vehicle is in R (Reverse). This allows the curb to be seen when parallel parking. The mirror(s) return to the original position when: . The vehicle is shifted out of R (Reverse), or remains in R (Reverse) for about 30 seconds. . The ignition is turned off. . The vehicle is driven in R (Reverse) above a set speed. To turn this feature on or off, see Vehicle Personalization 0 144 . |
#12 | |
#13 |
I'll get in there and mess with the settings, but this is not the option where the mirrors point down at the curb in reverse, I know for a fact i have that disabled. No big deal just wondered why it did it. Sounds like mine must be a special edition since it doesn't sound like anyone else's does it.
#14 |
Like mentioned above. Set where you want your mirrors and seat to be at exit and save it on the exit (3rd) button. Same as you programmed seat 1/2.
