Old 06-06-2018, 06:32 AM   #1
cfabrizio
Drives: 2018 Silver ZL1
S/C Boost Question
So this is my first car with a supercharger (2018 A10) and trying to see if what I notice is normal or if something needs to be adjusted.
I have noticed under acceleration that my boost pressure is not consistent. Some days when I accelerate, I seem to have decent boost and I can here the SC whining, other days when accelerating about the same the boost seems to only be at the neutral level (O on the gauge) and I don't here any whine. Also, some days when I rev the engine from idle I don't here any whine and other days I do. Now, under full throttle, the car pulls and whines like a champ, its the normal conservative driving that the boost isn't consistent.
Being inexperienced with forced induction, I thought that the boost would be a steady and consistent. If this is normal, is there a way to adjust things so the boost is more fluid and steady?
Thanks again and excuse the ignorance....cf
cfabrizio is offline   Reply With Quote
Old 06-06-2018, 07:27 AM   #2
TDS
TDS's Avatar
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10
My understanding is boost is controlled by a vacuum valve on the front of the SC. It closes to let the boost build. However the vacuum valve is overridden by the computer for a number of different reason ( Throttle position vs speed, traction control, IAT's, Ect…). As long as the car is accelerating smooth thru the gears and not cutting out, then I would say all is normal.
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats
Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer
TDS is offline   Reply With Quote
Old 06-06-2018, 10:22 AM   #3
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
You forgot Timing to.. mainly from air filter restriction and high IATs.
Old 06-06-2018, 05:09 PM   #4
Chevy71
Drives: 2016 2SS
If you want steady boost put your foot in it more. The valve on your screws opens and closes to allow boost to the engine. When you are getting inconsistent boost it's because you are teetering on that fine line of open and closing the valve.
Chevy71 is offline   Reply With Quote
Old 06-07-2018, 06:58 AM   #5
cfabrizio
Cool, thanks for the info!!
Old 07-24-2018, 10:00 AM   #6
tx915zl
tx915zl's Avatar
Drives: 2017 Camaro zl1
I noticed that when my M6 is at idle, the boost reads negative and if fluctuates up and down and it never stays at zero. Is this normal? on my 2012 cts v, when the car sat at idle it would read zero.
tx915zl is offline   Reply With Quote
Old 07-24-2018, 11:34 AM   #7
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
When it reads negative, that's vacuum. Perfectly normal.
Maybe your CTS V didn't show vacuum?
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 07-24-2018, 11:45 AM   #8
tx915zl
tx915zl's Avatar
I was a bit worried about it not being normal.
Old 07-24-2018, 04:19 PM   #9
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
Turbo cars are more sensitive but s/c cars are also affected by environmental conditions too.
I could discern the air quality in my old TT car by how quickly it would build boost!
Rlhay2 is offline   Reply With Quote
Old 07-24-2018, 05:09 PM   #10
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
++ Guarantee it just didn't show vacuum.
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
