Old 06-02-2018, 06:48 PM   #1
wjmeyer
wjmeyer's Avatar
Drives: 2016 Camaro RS, 2LT
What is recurring squeak/chirp noise??
Every 12-15 seconds, I hear a low-volume discreet squeak or chirp sound coming from the dashboard. It very easy to hear when the radio is on mute, but it normally drowned out by radio and (run-flat) tire noise when on the road.
Does anyone know what is causing this??
wjmeyer is offline   Reply With Quote
Old 06-03-2018, 03:40 AM   #2
Nookz
Drives: 2016 Camaro SS
Mine is currently in the workshop for that.
I figured out that the chirp occurs every time the AFM switches from V8 to V4 mode. Double check if that's the same for your car.
Nookz is offline   Reply With Quote
Old 06-03-2018, 10:03 AM   #3
wjmeyer
wjmeyer's Avatar
Mine was chirping every 12-15 seconds while I was parked, so it doesn't seem to be related to when my v6 switches to/from v4.
My oil monitor is at 5% and a message pops up at startup, could that be it? Nothing in the manual about it. I will be changing oil soon followed be a reset, hope the chirp goes away then.
Old 06-04-2018, 01:56 AM   #4
Nookz
Fan Motor?
Where exactly is the chirp coming from?
Old 06-04-2018, 10:32 AM   #5
wjmeyer
wjmeyer's Avatar
Its not a fan type chirp, its the kind of squeak or chirp that reminds you of something like when your cell phone battery or camera battery is close to 0%. It is coming from under the dash, more to the passenger side (it is not a device or something in the glove compartment).
I'll be out of town til mid next week and then I'll change the oil, reset the oil change reminder and hope that is the cause, although I don't remember that noise the 2 last times I changed the oil.
Old 06-04-2018, 11:43 AM   #6
Nookz
Sorry, no clue then.
Good luck!
Old 06-14-2018, 05:34 PM   #7
wjmeyer
wjmeyer's Avatar
https://clyp.it/edzkuqu0
This the mystery squeak coming from under the dashboard. It comes at the 7 second and 20 second mark, turn up your volume. It only does it while the engine is running. It was recorded with radio off and ac off. Can anyone identify it????
Old 06-14-2018, 06:18 PM   #8
Nitro66215
Nitro66215's Avatar
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV
Aliens
2018 2SS Vert - Hot Wheels - Indy 500 #30 - SOLD
2017 ZL1 Vert - M6 , SIM, CFW, NAV - SOLD
2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-(
Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 -
Heads-Up Display - DIY
2011 CTS-V - Black / Black - SOLD. :-(
2013 ZL1 - Black / Black - SOLD. :-(
2010 2SS - Indy 500 Pace Car. - SOLD. :-(
2002 Z28 - Pewter / Black - SOLD. :-(
Nitro66215 is offline   Reply With Quote
Old 06-14-2018, 07:58 PM   #9
918Stealth2SS
918Stealth2SS's Avatar
Drives: 2016 Camaro SS hyper blue
uhhhh. That's no squeak that's like some kind of chime like a cell phone. Bizarre I have no idea what that could be. How long has this been going on? After the 20 second one sounded like a plastic grind type sound. Was that you just grabbing the phone or like a blend door type sound concern?
2016 Camaro SS Hyper Blue Metallic A8 NPP/ ACS Spoiler / Krypton Green accents / Painted taillights & 3rd brake / Diode Dynamics LED sidemarkers
918Stealth2SS is offline   Reply With Quote
Old 06-16-2018, 10:04 AM   #10
wjmeyer
wjmeyer's Avatar
That was me just stopping the recording after 20 second beep. The beep/squeak started maybe a few weeks ago when I first noticed it, which it hard with runflat tire noise and with radio on.
Hopefully someone in the general section can identify the squeak or I may have to resort to bringing the car to the dealership to solve the mystery.
Old 06-16-2018, 11:55 AM   #11
tpavela
Drives: 2017 V6 1LE Summit White
I know I’ve heard that noise before but not from my car. For whatever it’s worth that same tone comes from my Sony Cybershot camera on power up.
I had my 14 year old daughter listen to both and she agrees.
tpavela is offline   Reply With Quote
Old 06-18-2018, 11:55 AM   #12
wjmeyer
wjmeyer's Avatar
I agree, it does sound like a digital camera. Thanks to your suggestion, I then checked my viofo dash cam and that was it. It was a format warning beep. Mystery solved.
