Old 06-02-2018, 09:01 AM   #1
Calubi
Drives: 2017 1SS 1LE
Minimum safe tread depth for tracking Eagle F1 Supercar Cup 3?
Hi all,
I'm curious what is considered the safe minimum tread depth for tracking the stock Eagle F1 Supercar Cup 3 tires? I have done two track weekends so far (four days), and the outsides are wearing a bit thin. Only 2600 miles on the odometer total. The outsides are wearing to close to 2/32, but the insides and middle are still 4/32-5/32. I plan on getting the car in to adjust alignment to the track settings, but I'm curious if I need to replace the tires before the next track event too due to the outside wear.
The rubber also seems to be getting a bit hard on the surface, any concern from that? Sidewalls seem fine.
2017 Camaro 1SS 1LE - Stock for now
2015 VW Golf R DSG - GIAC ECU/TCU tune
Calubi is offline   Reply With Quote
Old 06-02-2018, 09:13 AM   #2
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Change alignment to max camber up front..should see -2.4 or so.. -1.5r. The outside is different depth and shoulder groove design ..may not be as worn as you think.. look closer..
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 06-02-2018, 10:58 AM   #3
hms2488485
hms2488485's Avatar
Drives: '17 Camaro SS 1LE
Size:  188.9 KBThis is what my front tires looked like AFTER my last track day. This was taken after those were taken off about a week later. They held up strong and I didn’t have any concerns. I had 3 track days and 12,500 miles on them. Pushed them as far as I could haha
hms2488485 is offline   Reply With Quote
Old 06-02-2018, 01:00 PM   #4
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
You're exactly where I'm at after 3500 miles and 5 track days. You have more than 50% tread left since the main treads new are only 7/32 deep. That outside grove is more like a wear indicator than anything else, which can see from this pic of a new tire. I say you're good for at least another weekend or more but those with more experience than me will have more info
Old 06-02-2018, 07:00 PM   #5
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Fixing the alignment to track spec will help the tires last a little longer.
'18 1SS 1LE Black, PDR
Old 06-02-2018, 07:02 PM   #6
Boost Creep
Drives: '18 1SS 1LE
Originally Posted by hms2488485 View Post
Attachment 938923This is what my front tires looked like AFTER my last track day. This was taken after those were taken off about a week later. They held up strong and I didn’t have any concerns. I had 3 track days and 12,500 miles on them. Pushed them as far as I could haha
That's encouraging.
Hoping to get at least a year out of the GY's.
Old 06-02-2018, 07:50 PM   #7
Calubi
Thanks guys! That's promising.
Old 06-02-2018, 09:56 PM   #8
TrackClub
TrackClub's Avatar
Same thoughts as per the above. Id also say watch for any signs of cording especially on the outside edges. Then they are done for sure.
Old 06-08-2018, 10:15 AM   #9
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Just FYI it's Supercar 3, not Supercar Cup 3.
Old 06-08-2018, 11:18 AM   #10
TrackClub
TrackClub's Avatar
Good catch
Old 06-10-2018, 04:32 PM   #11
Gen_Nick3.8
Drives: 22 ZL1 1LE
once theres no belts showing the G3's will stay grippy
Gen_Nick3.8 is offline   Reply With Quote
Old 06-11-2018, 09:18 PM   #12
dantemcc
Correct me if I'm wrong, but doesn't the performance manual say that the track alignment will increase tire wear?
dantemcc is offline   Reply With Quote
Old 06-11-2018, 09:43 PM   #13
Boost Creep
Drives: '18 1SS 1LE
Originally Posted by Calubi View Post
Hi all,
OP was concerned with outside tread wear from track duty, and was thinking track alignment would help with wear.
I was confirming his thoughts on track alignment helping the tires last longer on the track.
He didn't mention tire wear on the street.
Old 02-04-2021, 05:39 PM   #14
Baddawg53
Drives: 17 hyper blue 2SS M6
Bringing back this old thread...
I see the holes in the outside tread block grooves, are those used as a tread life indicator similar to what a slick would have?
Baddawg53 is offline   Reply With Quote
