06-01-2018, 11:16 AM | #1 |
Drives: ZL1 1LE SUMMIT WHITE Join Date: Feb 2018
Harness Attachment Points
Curious what folks are doing for attachment for 5 or 6 point harnesses in ZL1 1LE.
Obviously lap and crotch belts only. |
06-01-2018, 08:09 PM | #2 |
Drives: 2017 Camaro SS 1LE Join Date: Sep 2017
Well I dont have the ZL1 but I have the 1LE. The crotch belt is on a custom base ( 2 of them because I have a 6 point harness). The left side Eye bolt and right side Eye bold is also attached to the custom base of the car. This only works because I have a racing seat installed.
06-02-2018, 10:32 AM | #3 |
I'd like to stick with the Recaros for now and perhaps make a change down the road.
06-02-2018, 10:52 AM | #4 |
Drives: ZL1 A10 Join Date: Dec 2017
You would have to cut a slot into the Recaro's for the sub-strap. Then attach to a base plate on the floor. If you don't have mounting sliders or fixed seat mounts with a cross member made for sub-strap mounting you will have to put a backing plate under the car and drill holes in the bottom of the car to provide bolts for mounting. The backing plate would be needed to give the sub-strap a fixed hold point when in a crash.
It would also not be advisable to do this without a roll bar and track shells. If you want to stay with the stock seats I may want to look at a Scroth DOT compliant 4 pt solution.
My rides:
2017 Camaro ZL1 A10 2015 Jeep Grand Cherokee Diesel 2012 Audi S4 1992 Porsche America Roadster 1990 BMW 325Ic |
06-02-2018, 11:00 AM | #5 |
Ya the bar is in hence the inquiry about Lap and Crotch belts only.
06-02-2018, 09:44 PM | #6 |
Anyone sliced a Recaro for a crotch belt?
08-21-2022, 08:33 PM | #7 |
BLEW BIU
Drives: 2018 2SS 1LE Hyper Blue Join Date: Oct 2017
5 point harness?
I’ve got a BK Harness bar setup with a 4 point harness. Could I not run a harness strap (crotch/anti-sub belt) between the cushions & attach it to my harness bar? Granted it won’t be as good as a hole in a racing seat attached to a bar beneath the seat, but I too want to keep my Recaro seats for DD.
08-21-2022, 09:14 PM | #8 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
You seem to have already excluded it, but I run a 4pt belt. Works nice for me with 200tw street tires and hawk 60s.
08-23-2022, 01:05 PM | #9 | |
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8 Join Date: Dec 2018
PS - love the booster seat in the back. ;-) Last edited by Eric10905; 08-23-2022 at 01:06 PM. Reason: added PS |
08-23-2022, 01:42 PM | #10 |
Drives: 2021 ZL1 1LE A10 Join Date: Aug 2020
You can run sub belts between the cushions without cutting a hole. The flap on the back of the seat will unhook from under the seat. You do need an attachment bar which do not seem to be easily available. I fabricated my own that attaches with the seat bolts. This allows you to run a 6 point harness. see pics
08-23-2022, 02:16 PM | #11 |
stock seats and belts or full race seat and cage/harness
08-23-2022, 05:35 PM | #12 | |
And as for the booster, it gets lots of LOLs during tech inspection at the track. |
08-23-2022, 06:56 PM | #13 | |
Drives: 2022 SS 1LE Join Date: May 2022
Chin and Edge Addicts state on their Tech forms either factory 3 pt belts or 5 or 6 pt harness. That said, I haven't seen them check closely whereas PCA does. There's also some good info on the hms site on setup geometry, anchor points, hardware, wrapping in slide bars etc. Just my approach but I look at it as a "system". Factory belts and airbags are a engineered system. but with a helmet there is additional mass around the head. A Simpson hybrid head restraint (models designed and tested for 3 pts) is a good upgrade. And rollbar (not just harness bar) plus seat plus 6 points with correct mounting and geometry and always a head and neck restraint (HANS) together form a "system". Hope that is useful. Last edited by NinthWave; 08-23-2022 at 07:13 PM. |
08-24-2022, 02:17 PM | #14 | ||
As for the car seat, I can beat. lol Quote:
Keep it on the black stuff guys. |
