06-01-2018, 06:47 AM | #1 |
Daily Driven 1LE
Drives: 2018 1SS 1LE Join Date: May 2018
Anyone with Borla 60606? Secondary cat deleted midpipes.
Do these really just bolt in place like the advertisement says? I'd love to have the ability to bolt in a new exhaust system and swap back to stock if needed. Apparently it works with the stock NPP too?
To good to be true or is cutting required?
2018 1SS 1LE
06-01-2018, 07:32 AM | #2 | |
Drives: 2018 ZL1 1LE - HBM, PDR Join Date: Jun 2017
Sent from my SM-G950U using Tapatalk
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
06-01-2018, 12:21 PM | #3 |
I know it’s a solution, but borla stuff isn’t cheap. I’d rather not cut anything, they really need to offer the right part so everything is bolt on
06-01-2018, 12:28 PM | #4 | |
On the other hand, if you are willing to replace the stock exhaust with a full cat-back connecting from the primary cats then it is a straight bolt on with no cutting of the factory exhaust required.
06-01-2018, 01:35 PM | #5 |
Drives: 2017 Black Camaro SS 1lE Join Date: May 2017
My question would be does a CEL come on installing the Borla mid pipe?
06-01-2018, 01:50 PM | #6 |
That was precisely my question too. Just finished the install last night so I don't have any specific experience to share yet. However there are a number of posts that indicate since the secondary cats are not monitored you will not get any CELs. However, some have noted getting CELs but was determined to be a leaky connection at the slip joint just after the primary cat (rear O2 sensors would pick this leak up). With the leak fixed, CEL goes away.
We shall see. Sent from my SM-G950U using Tapatalk
06-01-2018, 02:38 PM | #7 |
Drives: FRS Join Date: Jan 2017
I recently had a shop install the 60606 and CEL came on due to the shop re-using the OEM clamp on the driver side as mentioned in the post above.
The OEM clamp has since been cut off and replaced with the clamp Borla supplied and the CEL went away. We also applied some RTV to ensure a seal. Hopefully that's it. |
06-01-2018, 06:33 PM | #8 | |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
How happy are you with the S type? Sent from my iPhone using Tapatalk |
06-01-2018, 07:59 PM | #9 | |
At high RPM with quick decel you do get a fair bit of the Rice Krispies effect (snap, crackle, and pop) under the right conditions. If you like that, it's awesome sounding. If you don't, you probably would want to either add resonators or keep the secondary cats or go with a different setup. I have another thread I started a few days ago. I made a video of the before and after installs while on the lift. I also made a before video of the idle and revs with factory exhaust. And then just finished up the video of the Borla exhaust so you can hear the before and after. Under the same conditions. I'll be uploading and posting the Borla videos tonight. Sent from my SM-G950U using Tapatalk
