![]() Drives: 2016 Camaro SS Join Date: Jul 2016
What is the normal oil pressure level at WOT?
I checked the oil pressure level on dash at WOT, high rev and found it hit the high end.. almost 5 o'clock. And comming down as the rev down.
Not sure, but before I changed the smaller size pulley on SC, i think it was 3 o'clock at most at 6000~6500 rpm WOT Is it ok? |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
What weight oil, at what oil temps?
Temps_Grattan_May2018 by Ryephile, on FlickrHere's a capture from last weekend's track day with my SS. I'm running a Dexos2 0W-40. According to the PDR, around 220°F I'm seeing upwards of 62 PSIg, whereas at 270°F it peaks at 51 PSIg. How does that correlate to your observations?
I run the royal purple 0-30 dexos and mine is at least 70 lbs.
