05-29-2018, 12:17 PM | #1 |
Diffuser/belly pan for the Z/28
We have had many request to make a diffuser for the Z/28 and we now have them. They are made of 040 aluminum and made TO WORK, it will keep the rear bumper from being a parachute and create a belly pan at the rear.
see it here. https://zl1addons.com/collections/ch...-z-28-diffuser John ZL1 Addons www.zl1addons.com |
05-29-2018, 12:19 PM | #2 |
Instagram: Sangstah
That is awesome, good way to improve aero for the track!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
05-29-2018, 08:42 PM | #3 |
Drives: 2015 Camaro Z/28 - Silver Join Date: Apr 2013
big fan of zl1addons products. looks great!
Sent from my iPhone using Tapatalk |
05-30-2018, 10:12 AM | #4 |
Drives: 14 Z/28 #347 Join Date: Nov 2013
Ordered mine already
06-01-2018, 12:56 PM | #5 |
Drives: 2015 Z28 Red Hot Join Date: Jan 2017
This is off topic, regarding the dive planes for the Z28.
Have these been tested on track? Or are they purely for show only? I ordered mine a few months back and will be getting around to installing them this weekend. I'll be at the Roval in Fontana next weekend and should be hitting around 140mph so I wanted to double check
06-02-2018, 05:38 PM | #6 |
Drives: 17 SS 1LE, 14 Yukon Denali Join Date: May 2015
How does it attach to the car?
Sent from my iPad using Tapatalk |
06-08-2018, 08:10 PM | #7 |
I just installed mines. i ordered the non-powdered coated version and painted it myself to save some $$. install wasn’t too bad. it attaches to 4 existing screws by the lower part of the bumper and he provides you with a bracket and nut/bolt to attach to an existing hole by the cradle. you can maybe do the install without jacking it up, but it’s a pretty tight fit!! i ended up using my quickjack. took about 30 mins or so. Sent from my iPhone using Tapatalk Last edited by hollywdv; 06-08-2018 at 09:43 PM. |
06-08-2018, 09:42 PM | #8 |
Pay attention to details
Drives: 2012 ZL1 Join Date: Aug 2016
Sure would be nice for a 5th gen ZL1.
06-09-2018, 12:12 PM | #9 |
I got mine the only problem I see is that the three diffuser fins are held on by sheet metal screws that are going to come loose and fall off onto the track along with the fins. I'm replacing mine with a machine screw and a nyloc nut.
"The walls are white, the track is grey, the grass is green, and the sky is blue... your job is to keep them all where they belong." - Johnny Rutherford Last edited by Z Beast; 06-09-2018 at 12:51 PM. |
06-09-2018, 12:39 PM | #10 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Wish there was something like this for the 5th gen (2010-2013) SS. I already have a aluminum front belly pan installed
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
06-09-2018, 12:41 PM | #11 |
06-09-2018, 01:07 PM | #12 | |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
https://www.camaro5.com/forums/showt...n#post10035557 -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
06-09-2018, 03:04 PM | #13 | |
Wow that’s really cool! You should sell those, but make them out of aluminum instead of and plastic. I would be interested
06-09-2018, 04:01 PM | #14 |
ABS is very strong and I’ve road raced with this and not a single issue. Pretty stout!
-Don
747 RWHP 794 RWTQ
