Old 05-27-2018, 10:10 AM   #1
collinms
Drives: 2017 ZL1 A10 Summit White
Dip in power at higher rpms
I just went out for a Sunday morning drive and was pushing the car hard and noticed sometimes at higher rpms, maybe 5500 there is a dip in power that happens. It's almost like a surge, it's pulling fine then a dip then it returns. I was in track mode PTM race and I did not break traction. Do any of you experience this? Also is it just me or does it seem pointless to Rev it out to 6500? It feels like the car is pulling power at over 6000. I assume this is torque management because it's really noticeable in first and 2nd gear.
collinms is offline   Reply With Quote
Old 05-27-2018, 10:32 AM   #2
Bill_76
Drives: Camaro ZL1 2018
Yes same behavior in my A10
Bill_76 is offline   Reply With Quote
Old 05-27-2018, 11:03 AM   #3
Chevy71
Drives: 2016 2SS
a few quick questions; How many miles are on your car? Do you have factory plugs in it still? What fuel are you running and how long has it been in the car?
The TM system on these cars is very active, but tyipically the automatics are a little calmer because they aren't as hard on the driveline.
Your car makes max power around 5700 and that could be the biggest reason it falls on its face around and after 6k rpms
Chevy71 is offline   Reply With Quote
Old 05-27-2018, 02:48 PM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Rev limiter, perhaps?
Old 05-27-2018, 03:52 PM   #5
collinms
2500 miles, completely stock. Fuel is 93 and replace it often.
Old 05-27-2018, 03:53 PM   #6
collinms
No, not that I haven't revved it that high yet and it's an automatic.
Old 05-27-2018, 04:25 PM   #7
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
I noticed the EXACT same thing today with mine. I have a 2018 M6 with 1800 miles. I just did my second oil change yesterday.
I am glad to see I am not the only one seeing this. It is almost like it gets fuel starved for a second. But considering the amount of black soot I see on the outermost tail pipes, I believe she is running rich.
But this does look like a fuel curve issue... Or the fuel pump cannot keep up...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 05-27-2018, 04:51 PM   #8
collinms
I'm going to check my air filter tomorrow. Maybe there is a bunch of pollen in there or something. It might just be torque management though.
Old 05-27-2018, 05:09 PM   #9
Chevy71
Drives: 2016 2SS
That rules out your plugs and bad fuel from sitting through the winter. How hot was it outside ? The LT4 does pull top end power when its hot outside and your blower is pushing hot air in.. usually it's not real drastic though. With the detail you have given I would say the TM most likely.
Old 05-27-2018, 05:12 PM   #10
Koldunic
Drives: 2018 ZL1 1LE
Man..
First the M6 bog, second the left or right steer under WOT and now this?
I have a ZL1 coming in. I am afraid now.
I will follow this thread closely.
Koldunic is offline   Reply With Quote
Old 05-27-2018, 05:16 PM   #11
collinms
Originally Posted by Koldunic View Post
Man..
No no don't worry my friend. Even though this happens it's not that big of a deal. I'm just being observant and picky I suppose. The car is amazing and you should not be concerned. My car is perfectly stable and does not go side to side.
Old 05-27-2018, 05:17 PM   #12
nighttowl
Sarcasm loading --------
nighttowl's Avatar
most likely either timing is being pulled due to fuel octane or loss of traction was detected resulting in throttle being reduced.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 05-27-2018, 05:17 PM   #13
collinms
It was 80 this morning here.
Old 05-27-2018, 09:12 PM   #14
FASTNUF
FASTNUF's Avatar
Drives: 2017 ZL1 A10 White Vert
Mines a 2017 A10, no issue with mine except that according to the tach, it shifts slightly early from 1st to 2nd because it revs so fast and the tach can't keep up, lol. All other gears shift at redline like clockwork! No power dips. Only mod is RotoFab as an FYI.
FASTNUF is offline   Reply With Quote
