Old 05-25-2018, 09:12 AM   #1
sir574
sir574's Avatar
Drives: 2017 SS 1LE
Quoted for a procharger install
Got quoted by a local shop to install a Procharger P1SC kit. Just wanted to see if this is a fair price for what I'm getting. Also what kind of power should i expect to make with this on an otherwise stock car?
Thanks!
sir574 is offline   Reply With Quote
Old 05-25-2018, 09:21 AM   #2
oldman
Drives: SS 6 speed of course
Seems high to me, unless this includes dyno runs before after and a tune. The Procharger was an easy peasy install, I've done 3 now. I'm old and slow but say 10 hours for me at 120 an hour = $1200 all in. Procharger has dyno runs, I believe 550 whp SAE on a dynojet.
https://www.camaro6.com/forums/showthread.php?t=529853
Old 05-25-2018, 09:23 AM   #3
sir574
sir574's Avatar
Drives: 2017 SS 1LE
Seems high to me, unless this includes dyno runs before after and a tune. The Procharger was an easy peasy install, I've done 3 now. I'm old and slow but say 10 hours for me at 100 an hour = $1000 all in. Procharger has dyno runs, I believe 550 whp SAE on a dynojet.
This does include dyno tuning
Old 05-25-2018, 09:23 AM   #4
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
8-10 hour install.
Guys do it in 8 in their garage.
This shop is either charging $200 an hour or $100 an hour for a 20 hour install.
Should be $1200-1500 max.....then the $500 discount.
Or as others have asked. Does it include pulls and tune. That's about $600-$800 there.
Old 05-25-2018, 09:28 AM   #5
sir574
sir574's Avatar
Drives: 2017 SS 1LE
8-10 hour install.
Guys do it in their garage including the install of the inter-cooler? I was told because my car is the SS 1LE its more work due to all of the extra cooling lines in the way.
Old 05-25-2018, 09:48 AM   #6
oldman
Does the 1LE have more coolers? I know it has an ediff… but I don't know where GM would put a cooler. My SS has 3 radiators, an oil cooler, and trans cooler in the front and a diff cooler n the rear. The front is filled with ducts, absolutely filled.
Old 05-25-2018, 10:28 AM   #7
sir574
sir574's Avatar
Drives: 2017 SS 1LE
sure you dont have a 1LE? lol
the SS doesnt come with those additional coolers, but the 1LE has all what you mentioned.
Old 05-25-2018, 10:45 AM   #8
BradfordCamaro
SABIO
SS has all those rads and coolers
I have one.
Old 05-25-2018, 10:53 AM   #9
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
I was quoted 1300 for install and dyno tune, also thats high for that kit, shop around
DapperDan is offline   Reply With Quote
Old 05-25-2018, 12:00 PM   #10
L78toLT1
L78toLT1's Avatar
After pulling my front fascia off twice, once to replace the lower grill and once to install the intercooler for my Maggie, I honestly believe I could remove and reinstall the front end in 30 minutes. I'm sure the shop is faster than I am. The intercooler added another hour or so but would be less for a shop that has done several similar installations.
Baby Blue
Old 05-25-2018, 12:06 PM   #11
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
The SS has the same coolers. Your car is just as easy to install a ProCharger on as every other 6th Gen.
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 05-25-2018, 12:25 PM   #12
sir574
sir574's Avatar
Drives: 2017 SS 1LE
strange, so why does GM advertise the additional coolers for the 1LE package if they aren't actually additional?
Old 05-25-2018, 01:40 PM   #13
d729596
d729596's Avatar
Drives: 2016 SS Hyper Blue
Make it look exclusive when it isn't. Ss also have same engine, transmission and dual mode exhaust. The exclusive list just got smaller
d729596 is offline   Reply With Quote
Old 05-25-2018, 01:40 PM   #14
Inkedmongo
Drives: 2ss
What are your end goals with it? If you don't want to hassle with upgrading your entire fuel system and getting caught up in a spending frenzy then the P1 is a good setup, but I would go P1X.
Check other shops and compare prices on labor if you are not comfortable doing the install yourself. If they keep throwing out huge mark up on parts and labor then order the parts yourself.
Inkedmongo is offline   Reply With Quote
