Old 05-24-2018, 09:31 PM   #1
kttxz06
kttxz06's Avatar
Drives: '18 Zl1. '18 GT350.
DR's Installed. TC comes on all the damn time now.
Just put on my MT Streets. 305/35/20's. TC blinks all the damn time now, car seems to rev out. I turn all nannies off, runs fine.
Something my tuner can help with on calibration or just way of life?
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
kttxz06 is offline   Reply With Quote
Old 05-24-2018, 09:44 PM   #2
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
Did he even finish tuning it yet? Is the cam installed?
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 05-24-2018, 09:46 PM   #3
kttxz06
kttxz06's Avatar
Nope, we are never done tuning. Last pull was 803/768. Running into heat issues honestly, so not too pleased, but I just ordered my ice tank and block plates so we can get some more flow going. And yes, cam is done and we CNC'd the heads, ported the blower and snout while the motor was apart.
Should be going back again..........sometime end of next week to dial it in. Was hoping for 850ish. Not sure if I'll hit that # in this Houston heat right now.
Old 05-24-2018, 10:17 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
The 35 aspect ratio is causing a problem. The difference in diameter between the front & rear tires is causing your issue. I think your tuner can resolve it easily.
Old 05-24-2018, 10:25 PM   #5
laynlo15
Drives: 2022 Lt1 A10
Can't change it, just can't be over an 1" diameter difference. But, you are probably over the 1" difference as stated above.. Just run a taller tire in the front and should be good to go.
Old 05-24-2018, 10:28 PM   #6
yeah, you're over an inch taller than stock. Matt can fix that.
Old 05-24-2018, 11:18 PM   #7
kttxz06
kttxz06's Avatar
Thank you sir.
Old 05-24-2018, 11:21 PM   #8
kttxz06
kttxz06's Avatar
Thank you. Yea, I shot him out an email. i figured it was something like that. If anything, I can roll with nannies off now. These DR's grip like a mutha now so. I did a few WOT hits with nannies off and it stayed straight so. Drive home in the rain was interesting yesterday when installed. haha.
Next up. 100 shot!!!!!!! Maybe 150.
Old 07-11-2018, 07:42 PM   #9
meSSohappy
meSSohappy's Avatar
Drives: 2018 ZL1 A10
How did you get that tire to fit without rub issues? I have them on my 18 ZL1 and they rub the inner fenders, even with 8mm spacers they barely clear.
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
meSSohappy is offline   Reply With Quote
Old 07-11-2018, 08:02 PM   #10
kttxz06
kttxz06's Avatar
I have aftermarket wheels so the offset is different. I do still get a little rub since I'm on BMR springs. But nothing major.
Old 07-12-2018, 10:27 PM   #11
meSSohappy
meSSohappy's Avatar
So I was able to run my DRs on the street with a 4mm spacer. Got 8 turns on my lug nuts. There was still some rubbing going over bumps but all wil be ok at the strip. I did a burnout on the street and picked up some loose gravel on the way home. It appears the rubbing is from the rocks that got stuck in my tires.
Old 07-13-2018, 09:12 AM   #12
ICTsccaCamaro
Drives: 2018 ZL1 1LE
What I think of when people put taller than stock height tires on a camaro....
ICTsccaCamaro is offline   Reply With Quote
Old 07-13-2018, 09:49 AM   #13
aka Reckless
aka Reckless's Avatar
Drives: 2016 2SS Camaro
FWIW, I would not recommend running TC ever with a boosted car and modified tune (when you are full throttle). When TC is enacted the tune is altered and may cause engine damage.
aka Reckless is offline   Reply With Quote
Old 07-13-2018, 11:48 AM   #14
kttxz06
kttxz06's Avatar
I leave all nannies off now anyways.
