Drives: 2010 RS/SS Join Date: Dec 2010
New product...manual fan switch!
We are now offering plug and play manual fan switches for Gen V Engine platforms: 2016+ Camaro, 2016+ Cadillac CTS-V, 2014+ Full Size Truck, and 2014+ Corvette also! Check them out here - Manual Fan Switch. Special introductory pricing will only be available for the first month!
This harness plugs inline to your factory fan harness and allows you to override factory settings for both Low and High. Great for track use or added cooling!
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
Will the fans ONLY work with the switch or still work when the car tells it to turn on the fans?
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
SABIO
My fan runs on high all the time....
Hmmm. Better get that checked in my tune
The switch is just an override. So if it is in the off position, the ECM will continue to control the fans as normal! If you turn the switch to Low or High, it overrides the ECM and switches them on to that setting. Thanks for your question!
Will this allow you to switch the fans on when the engine is off?
#6 | |
https://www.camaro6.com/forums/showthread.php?t=525099 I'm checking my temp switch on the water pump, but unlike the thread above, my temp gauge works. The ProCharger setup has the MAF cables HARD against the fan shroud, (the could have pivoted the MAF maybe 5 degrees toward the engine)! The reason I mention that is the intake temp sensor is in the MAF. Dunno but the car thinks and acts like it is overheating but the gauge etc says normal operating temp.
#7 | |
![]() Drives: 2016 Camaro 1SS Join Date: Feb 2018
Ray |
#8 | |
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
#9 |
It does not have a timer, it will run so long as you have the switch in the ON position.
These have been working great for us so far! Sorry I didn't answer your question sooner, things have been insane around here, in a good way
#10 |
Thanks for the recent orders on these - glad to be getting them out - they've been working great for us! Just in time for those cool fall track days.
#11 |
Thanks for the info on this, perfect for sitting in the staging lanes. Once I get my new motor in I'll get one of those ordered. Nice product.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i actually read about this on superchevy and posted this up a few weeks ago looks like a cool product! any other new 6th gen camaro parts in the works?
#13 |
I run at a very busy track and always have a problem keeping cool in the staging lanes. We were going to hard wire it and run wire for a switch so no need to do that now. They have it covered.
#14 |
Moderator
+1
