![]() Drives: 2018 Nightfall Gray Metalic ZL1 A10 Join Date: Feb 2018
Car was stuck and then POP!
Hello Folks,
Relatively new A10 ZL1 owner here. Bought it with 710 miles and have 2500+ on it now. I haven’t driven it for about 10-12 days due to non stop rain except for maybe pulling it out of the garage a few feet to wash it. Today was the first day it didn’t rain and the roads were dry so I took it for a quick spin. The weird part happened in the garage as I was trying to back it out. I turned it on put it in R and nothing (felt like the parking brake was engaged). I engaged and disingaged the parking brake and still nothing. I proceeded to put it in D, the neutral, still nothing. I finally put it back in D, made sure the PARKING brake was disingaged and then gently depressed the gas pedal. That’s when I hear a popping sound and a slight jerk before it finally engaged. After that everything seemed fine. Anybody else had this experience |
Did you wash it before you put it away or were the brakes wet from rain? Sounds like the brakes seized to the pads, nothing abnormal, my cars do it all the time.
Caliper may be stuck.
![]() Drives: 2017 SS 1LE Join Date: Mar 2017
Simply the pads locked on the rotors. Pads in the six piston caliper cars do that after washing. Drive it around the block and drag the brake a few times...before you put her to bed
![]() Drives: 2017 BLACK ZL1 A10 Join Date: Jan 2018
Just had this happen to me today. Car was parked outside in the rain for 5 days and had some rusty rotors. Car didn't move in reverse and I gave it some gas and heard a large clunk. Had to have been the pads stuck to the rotors.
I wouldn't worry about it.
'17 Mosaic ZL1 Katech TB, Plugs/Wires, Rotofab Oiled,+18% Lower, 2" Headers, Cat Delete, 93 Tune, Mobil 1, IPA FF04, 315/30/20 r888r, 664hp/693tq (93), 702hp/727tq (100 oct)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
As mentioned a stuck caliper would be the best bet especially since you’ve washed and not driven it. I’d use a blower on the wheels after washing if you can’t drive it afterwards.
#7 |
Anyone else notice how easily our rotors develop surface rust?
#8 |
I absolutely did wash it just before I put it away.
Thanks for the feedback. I am a little wiser now. |
#9 | ||
#10 |
![]() Drives: 2017 Camaro 2SS / 2012 CBR1000RR Join Date: Jul 2017
This is why I belong to this site. So much info and experience shared freely.
#11 | |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
Anyway, OP, +1 to the others' suggestion, definitely drive the car after washing and get a couple 30-0mph braking points in (stop signs, etc) before parking to avoid the stuck pads. |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I always drive mine back back and forth down the driveway on the brakes a few times because of this. As mentioned above, all my performance cars have done this.
#13 |
good info - did not know this!
#14 |
![]() Drives: 2017 Hyper Blue A10 ZL1 Join Date: Dec 2016
This is not unique to our cars. This sometimes happened with my GT3 as well, and has happened quite a few times with the ZL1. It is pretty easy to avoid. When I wash my ZL1 or come in from the rain, I brake while I slowly drive after to get rid of the moisture on the brakes. Then park. Then no freeze up. If you can't do this, you can move the car. a while after parked This only seems to happen when put away wet, and then not moved for a day plus.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG etc.. |
