Old 05-20-2018, 07:47 PM   #1
laynlo15
Drives: 2022 Lt1 A10
Ice box for lower intake temps
Getting my ice box built this week, hot temps are moving in so gotta keep my intake temps down since I'm running more boost this year. Its also much easier on the engine and will probably go ahead and change the t stat while I'm at it. Dustin is building me a 4 or 5 gallon tank that will hold about 20 to 25 lbs of ice. Gonna have to buy me a really big cooler to take ice to the track. I should be able to drop my intake temp about 25 to 30 degrees or about the ambient temp outside. It will be trunk mounted and should have it done next week to try it out at the Street Car Takeover in St louis June 1-2nd.
Old 05-20-2018, 08:48 PM   #2
Epx998
|Engineer|
Epx998's Avatar
Drives: 2016 Camaro SS
What should the intake temperature be around?
2016 Camaro SS A8 | Magnuson Heartbeat | Might Mouse Wild Catch Can | DSX Flex Fuel | Eibach Pro Kit | Flowmaster Outlaw Black Series | MRR 017 Wheels
Epx998 is offline   Reply With Quote
Old 05-20-2018, 08:55 PM   #3
toohighpsi
Drives: 2015 C7 Z06 M7
For me, I like them to stay less than ambient , but if I can't manage that then about 140F is the max I want to see at the end of the 1/4 mile to maintain good power.
Old 05-20-2018, 09:15 PM   #4
laynlo15
Usually you don't run into issues until you see higher boost levels like mine which is around 14-16 lbs of boost. I really never saw higher temps at even 10 to 11 lbs of boost, just want to push this setup as hard as possible without any damage. Most boosted cars that run higher boost run an Ice Box, I still have one more pulley size to go down to and I need to see lower temps down track to do that. Most street cars running 7 to 10 lbs don't have issues. I'd still like to run a few more lbs with my 70mm pulley, maybe I'll get to do that this year. I remember how hot it was at the Camaro fest last year, I'm sure it will be close to that in Bowling Green this year so I'm just getting prepared.
Old 05-20-2018, 09:41 PM   #5
Epx998
|Engineer|
Epx998's Avatar
In traffic I see 130-150 and that seems a bit high. Today in cooler weather, no traffic I was around 100-ish. But in the commute, forget about it.
Old 05-20-2018, 10:15 PM   #6
ShizzySupra
Drives: 16' Camaro 2SS
This is me...super jealous of everyones intake air temps less than 190....
But I am gonna get it fixed :P
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 05-21-2018, 04:49 AM   #7
laynlo15
190? I guess the more mods the higher intake temps will follow.
Old 05-21-2018, 06:43 AM   #8
cheeze9878
cheeze9878's Avatar
Drives: 17 camaro ss
Has anyone seen or used this as an alternative?
https://killerchiller.com/products/u...l-parallel-kit
I was thinking about this for a twin turbo setup over the winter
cheeze9878 is offline   Reply With Quote
Old 05-21-2018, 09:00 AM   #9
Inkedmongo
Drives: 2ss
Call these people and have them hook you up.
http://fiinterchillers.com/what-we-do/
Inkedmongo is offline   Reply With Quote
Old 05-21-2018, 03:55 PM   #10
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
Sounds like a fun and worth while addition to your car. I have a few questions as I genuinely interested. Are you going to run an upgraded pump? Have you though of upgrading the heat exchanger (thickness, width)? Have you thought about the priority for water flow (tank, to blower, to heat exchanger, to tank)?
Turbo_RORO is offline   Reply With Quote
Old 05-21-2018, 05:41 PM   #11
Drsagacity
Drsagacity's Avatar
Laynlo...you are crazy!
Stock internals and stock exhaust + upgraded fuel + Maggie = 700rwhp and currently a 10.0 ET. (Soon to be 9.x’s)
When you are done racing, swing by my house, driving on the highway with 25mpg...sick. Well done sir.
Of course, pushing the stock internals this far is insane, but I just can’t quit watching.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 05-21-2018, 06:55 PM   #12
laynlo15
Since I just drag race and don't really drive it on the street anymore this is the efficient way to go. I won't be removing any other pieces to the intercooler and may using some sort of valves to switch from strip to street. Yes we are using a Rule 2000 installed in the rear and it will be on a toggle to switch turn on the system when its time to do the burn out. I'll have to take about 50 lbs of ice to the track each time. Yes I still may go to a larger intercooler sometime in the future, but we will see how this motor holds up this year before any other decisions are made. If I can keep it cooler I can make the motor last longer for sure. I'll be changing the t stat also, the boost is just making it tougher to keep cool but we can do it.
Old 05-25-2018, 12:17 PM   #13
L78toLT1
L78toLT1's Avatar
Has anyone tried the weaponx trunk cooler?
Baby Blue
Old 05-25-2018, 12:49 PM   #14
Krypton1le
Drives: 2017 Camaro SS 1LE Krypton Green
Weapon X also has a kit to replace the front 3 HX's (intercooler, aux intercooler, and aux radiator) that I was looking at for down the road. Not sure if anyone has experience with that?
Krypton1le is offline   Reply With Quote
