Old 05-20-2018, 12:38 PM   #1
ScottMZ3
ScottMZ3's Avatar
Drives: 2018 ZL1 A10, 2019 BMW X5
Top corner of rear bumper not flush to fender
Anyone else have this issue? Tired searching forum and didn’t come up any hits. Both sides are like this. Any easy fix? Or am I looking at having to remove the whole cover to fix. The car has not been bumped or rear-ended.
Not sure why photos are rotated.
2018 Nightfall Gray Metallic Camaro ZL1 - A10
Purchased 9/23/2017
ScottMZ3 is offline   Reply With Quote
Old 05-20-2018, 12:48 PM   #2
ScottMZ3
ScottMZ3's Avatar
Ok that’s weird. Those pics were from yesterday after I had returned from driving the car awhile. Just went out this morning to look again and now they are flush! WTF? Heat related or something???
Purchased 9/23/2017
Old 05-20-2018, 01:18 PM   #3
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
Very interesting. A buddy has a 2018 ZL1 1LE and he reports the same thing, identical to your experience. I have the same car and never this issue. We live in the same area so the weather is virtually the same. Mine is HBM and his is black (dark like yours). Maybe it is a heat thing like you suggest and the dark colors are more problematic because of the heat absorbtion.
I noticed you are in Roseville and in our backyard. It will be interesting to see if the problem becomes more pronounced as the summer months roll on.
Sent from my SM-G950U using Tapatalk
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 05-20-2018, 01:21 PM   #4
devnull
Scientific negotiator
devnull's Avatar
Drives: 2019 Grand Sport
My ZL1 1LE (White) has the same issue. Was going to pop the tail light out of it and see if there is a way to pull it in. Will let you know.
devnull is offline   Reply With Quote
Old 05-20-2018, 01:39 PM   #5
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
same issue here
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 05-20-2018, 01:44 PM   #6
ScottMZ3
ScottMZ3's Avatar
Definitely strange! But it must be expansion of the plastics in the heat. Glad there is another ZL1 in the area. I've still only seen 2 in the area since the ZL1 came out!
Keep us posted! Seems like I'm definitely not alone with the issue.
Purchased 9/23/2017
Old 05-20-2018, 02:23 PM   #7
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Following
2018 ZL1 1LE sw/PDR
Old 05-20-2018, 05:47 PM   #8
URBAN LEGEND
URBAN LEGEND's Avatar
I got it bad on drivers side. A little on passenger side. Whatever. It’s still runs hard.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 05-20-2018, 06:00 PM   #9
devnull
devnull's Avatar
Folks,
I was able to correct this pretty easily (took 15 minutes using a couple of tie wraps). If needed, I will post a full writeup on how to remove the tail light but for the below just assume you have it off already (it is easy). If you search online there a ton of youtube videos on it since many of the SS guys (myself included) swapped out our red tail lights for these awesome 1LE ones!
Here is a before pic of the badly misaligned bumper. Ouch!
Remove the tail light and you will see that just under it are the tabs that the rear bumper hang on. These tabs do not hold the bumper tight enough, so we are going to help it a little.
Use a couple of tie wraps on the inside edge of the tabs and pull tightly while someone holds the bumper into the right alignment spot. Those tie wraps will pull the bumper into place and hold it into the right spot. (see below)
Put the sucker back together and behold your properly aligned bumper for your very expensive Camaro!
Old 05-20-2018, 08:04 PM   #10
ScottMZ3
ScottMZ3's Avatar
Awesome!!! Thank you for posting this!! I’ll give this a try.
Purchased 9/23/2017
Old 05-20-2018, 08:15 PM   #11
DangerZL1
Drives: 2023 Black ZL1 Auto
Wow! Great idea. This should be a sticky.
Old 05-20-2018, 10:16 PM   #12
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
Take that Bitch straight to the dealer, that would have made me sick.
speedraider is offline   Reply With Quote
Old 05-20-2018, 10:21 PM   #13
devnull
devnull's Avatar
I agree, but hate to let someone else do these type things before I give it a shot first. This one seems pretty simple so far..
Old 05-21-2018, 05:38 AM   #14
URBAN LEGEND
Dealer will find a way to ass drag their butts on your seats and create more issues elsewhere.
🔺22 RS E TRON GT
🔺21 Model S Plaid
