Old 05-20-2018, 10:33 AM   #1
Todd_Cooperider
Drives: 2022 ZL1 Convertible
Ready for Mid-Ohio, so took some photos of the ZL1 1LE!
I'm heading out to Mid Ohio tomorrow for a track day, so I decided to take some shots of the car.
As for prep, we swapped back to the stock wheels/tires (I have Forgelines with Michelin 4S for the street), went with track camber, track alignment, raised the front to 690mm, changed oil, changed brake fluid (Motul RBF660), etc, etc. I also have the complete car wrapped in STEK DYNO Shield film for max clarity (protection AND looks!).
I'll be interested in seeing how the car does at the track, and compares to my previous Z06/Z07, and 991.2 Turbo S.
Enjoy the photos, and I'll report back after the track day...
Todd_Cooperider is offline   Reply With Quote
Old 05-20-2018, 12:31 PM   #2
dgreenberg
dgreenberg's Avatar
Drives: ‘14 Z/28 #352, ‘16 ACR,
Can’t wait to get mine broken in and track prepped! Only difference is I’d be going to the local to me Utah Motorsports Campus!
dgreenberg is offline   Reply With Quote
Old 05-20-2018, 12:54 PM   #3
full*throttle*therapy
Drives: '18 RH ZL1 1LE
Every time I see a pic of a RH ZL1 1LE, I think to myself "Damn that's a fine looking car!" ..and then I remember to look in my garage
full*throttle*therapy is offline   Reply With Quote
Old 05-20-2018, 01:18 PM   #4
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Looks great!
Badge delete is awesome! I'm going that route as well.
Have fun at MO.
2018 ZL1 1LE sw/PDR
Old 05-20-2018, 01:31 PM   #5
dchesrown
Drives: ZL1-1LE
Post some videos of your runs. Also, post lap times.
dchesrown is offline   Reply With Quote
Old 05-20-2018, 01:50 PM   #6
misterjaayy
Drives: 2019 CTS-V
Great shots and beautiful looking car.
misterjaayy is offline   Reply With Quote
Old 05-20-2018, 01:58 PM   #7
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
I always love mid-ohio on the bike and in the car.
Have fun
TLSTWIN is offline   Reply With Quote
Old 05-20-2018, 02:03 PM   #8
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Raised the front? Usually track prep would be the opposite.
Provoste is offline   Reply With Quote
Old 05-20-2018, 02:25 PM   #9
tm5
Drives: 18 ZL1 1LE
Your car looks a bit lower in front - you sure it was raised? Did you keep the rear bar in the middle adjustment?
Love Mid Ohio - enjoy!
tm5 is offline   Reply With Quote
Old 05-20-2018, 02:32 PM   #10
Todd_Cooperider
That's a beautiful track you have out there!
Yes, Red Hot is pretty spectacular!
Looks great!
Have fun at MO.
Look forward to seeing it!
Will do.
Thank you.
Have fun
I've done countless laps there on two wheels as well...love the track!
Yes. The Camaro team designed the handling characteristics around a minimum of 690mm in the front.
Yes, it sits at 690mm which is up slightly from where it came stock. Thanks.
Old 05-20-2018, 03:58 PM   #11
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Interesting, a "minimum of 690mm" so that is the lowest it should be?
Where did u find that information, that would be an interesting read.
Wonder if it is a ratio to the rear height? I understand raising the front and corner balancing, just not sure where this car sits from the factory and where optimal height and weight is for this car at mid-ohio.
Seen some video of guys at mid-ohio already, and u can see and hear where areas can be improved. I have recently been rewatching some of my own videos and wondering what I was thinking at each corner. Lol
Old 05-20-2018, 04:19 PM   #12
Todd_Cooperider
Well, you won't find that information in their printed material. I have a bit of an "in" with development people on the team and they gave me that advice.
Assuming you're talking about my Z06 video, I've already knocked over 4 seconds off of that time, so yes...definitely areas for improvement based off of that video!
Old 05-20-2018, 04:25 PM   #13
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
No, not any of your videos, guys with ZL1s and ZL1-1LEs
So it is assuming the rear height is oem, or a certain height then? If the whole car is lowered, 690mm would no longer work. What is the rear?
Now I gotta go watch your videos, lol
Old 05-20-2018, 04:33 PM   #14
Todd_Cooperider
Stock height on the ZL1 1LE rear...not sure why anybody would want to lower it more. Stock height, full tank of gas, measured on a level surface. Ground to the center point of the underside of the front fender.
