Old 05-18-2018, 05:48 PM   #1
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
Question SS groaning at low rpms.
My '18 1SS is making a low pitched groaning noise that is most noticeable within the first 10 minutes after engine start. It sounds sort of like a low pitched microwave oven with just a hint of a metallic sound. It comes and goes, lasts for maybe a couple seconds at a time then disappears. That makes it hard to follow or figure out. It happens more often if the car is cold and at low rpms, like when the auto is bogging down. I hear the groan mostly when driving very slow, like 15 mph through neighborhoods. Stepping on the gas and getting the rpms up always makes it go away. Changing to manual mode and forcing the A8 to stay in gear 2 or 3, instead of 4, also prevents it from happening.
Is this expected behavior for the A8 trying to maintain low revs?
protovack is offline   Reply With Quote
Old 06-03-2018, 02:12 AM   #2
protovack
updated original post with more detail.
Anyone?
Old 06-05-2018, 03:03 PM   #3
PatrickRodriguz
Drives: 2018 SS
I believe I am having the same problem however it is not constrained to 10 minutes. At any point in any gear around 1000-2000 rpm with about 10% throttle applied, you will hear a low gurgling sound.
PatrickRodriguz is offline   Reply With Quote
Old 06-05-2018, 06:08 PM   #4
HackSaw
HackSaw's Avatar
Drives: 2017 Camaro SS
Any chance its coming from the sound tube? It enters the cabin above the gas pedal Plugged mine with foam
HackSaw is offline   Reply With Quote
Old 06-06-2018, 02:05 PM   #5
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
Do you have the NPP exhaust?
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 06-12-2018, 02:28 AM   #6
protovack
Yes I have NPP exhaust, but it doesn't sound like the NPP rattle.
It literally sounds like a big microwave oven coming on for seconds at a time, then going away.
Old 06-12-2018, 03:50 AM   #7
bpang1234
bpang1234's Avatar
Pull the NPP fuse and drive around to see if it is that. I have that same sound and it comes from when the NPP is partly closed but not quite closed enough to only flow through the muffled side of the setup.
However, mine only makes that sound when the Supercharger is running because when my belt broke it stopped making the sound making me suspect that the NPP valve isn't quite strong enough with boost flowing through.
Actually, if you are still in warranty, just go get it checked out...before you go, use your phone to take video of the noise so they don't tell you "our mechanic couldn't reproduce the noise".
2016 Camaro 2ss
