Old 05-17-2018, 01:40 AM   #1
MeanZL11LE
MeanZL11LE's Avatar
Drives: 2018 ZL1 1LE
Camber adjustment on ZL1 1LE?
So I'm planning on tracking the car and wanted to set the front wheels at - 2.7 per GM recommendation. This car has 3 bolts you remove on the shock tower and spin 180 deg to add - 1.7 camber to the factory - 1. Seems really "easy" and great idea.
My question is 1) has anyone tried this? 2) did it alter the toe, as I assume it would?
Thanks in advance for any helpful advice.
Sent from my SM-G960U1 using Tapatalk
MeanZL11LE is offline   Reply With Quote
Old 05-17-2018, 04:37 AM   #2
URBAN LEGEND
URBAN LEGEND's Avatar
I have not. Interested in a quick overview.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 05-17-2018, 04:47 AM   #3
djoker08
HTCC Member
djoker08's Avatar
Drives: 2018 ZL1 1LE HBM
It is easy to do and the toe does change after you switch it, my alignment was off after switching it.
djoker08 is offline   Reply With Quote
Old 05-17-2018, 05:43 AM   #4
2010REDSS
2010REDSS's Avatar
It's best to switch to the "Track Camber" settings, then get the entire car aligned to the track alignment recommended in the manual.
That alignment has worked well for me at RoadAmerica and Road Atlanta.
2018 ZL1 1LE "RAZECAR"
2016 2SS Convertible "NOTOPSS" (Sold)
2015 Z/28 #306 "ITZFAST"
2010 2SS Coupe "FASSTER" (Sold)
2002 SS/RS "02FASST" (Sold)
2007 Factory Five Racing GTM "REDBLUR" (Sold)
"There are two kinds of cars. Red....and everything else!"
2010REDSS is offline   Reply With Quote
Old 05-17-2018, 10:38 AM   #5
MeanZL11LE
MeanZL11LE's Avatar
I wanted to set up the car myself. Where did you take it for the track alignment?
Old 05-17-2018, 10:40 AM   #6
MeanZL11LE
MeanZL11LE's Avatar
So what did you do for alignment after switching it?
Old 05-17-2018, 10:47 AM   #7
ICTsccaCamaro
The top mount or camber plate it kinda a PITA to rotate, the mount has mounting ears for the bolts and inside of the shock town has some reinforcement ribs that cause the two parts to hang up when you are rotating them around. I set mine in the "track camber" setting and put it on the alignment rack and had -3* of front camber and of course the toe was way off due to camber changing. Since I trailer to and from events i'm just going to leave mine in the track camber setting for the life of the car.
ICTsccaCamaro is offline   Reply With Quote
Old 05-17-2018, 11:03 AM   #8
2010REDSS
2010REDSS's Avatar
Chevy dealer.....got a sharp mechanic there that is the only one that is allowed to work on my car....while I watch.
Old 05-17-2018, 11:12 AM   #9
Xlr8ion
Drives: 2013 Cayenne GTS
This topic has been beat to death
Xlr8ion is offline   Reply With Quote
Old 05-17-2018, 11:43 AM   #10
tomster
RedLine
Drives: 2022 ZL1 1LE
Its not hard but its not as easy as GM makes it sound. Like others said you have to drop the strut down to rotate it because the tabs hit.... Yes An Alignment is required after.
tomster is offline   Reply With Quote
Old 05-17-2018, 11:56 AM   #11
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
It's best to lift the entire front end up at once. jacking up one corner forces the stabilizer bar to resist the strut dropping and can cause it to hang up.
It's convenient you asked this - I've done this before several times.
But I'm having the car aligned twice at Tom Henry Chevrolet this Saturday. We will align it in street mode, and then switch the camber and height adjustments and take a measurement. If it's not right - we're going to re-align it...and then switch back to street settings to see what THAT does.
The camber and toe measurements are dynamic, and change with the geometry of the suspension.
Old 05-17-2018, 11:59 AM   #12
silverbullet415
silverbullet415's Avatar
Drives: 2018 Camaro ZL1 1LE
https://youtu.be/z9p4pNiqzrE
I made his when I did mine
silverbullet415 is offline   Reply With Quote
Old 05-17-2018, 12:15 PM   #13
Slate993tt
Slate993tt's Avatar
Drives: 2018 Silver ZL1 1LE
It's easy to do but the Toe will be waay off. I was able to get it to -2.7 on both sides in my garage using wheel Camber gauge but the toe was out. I had it all done by a good Alignment shop by my house. Just note that for the rear the bolts are 1-time use so have a place that has access to a chevy dealer or bring bolts with you.
Where in Socal are you? I'm up in Camarillo(Ventura County). If near here PM me and I'll shoot you who I used and what it cost etc.
Slate993tt is offline   Reply With Quote
Old 05-17-2018, 01:09 PM   #14
dlct3
Interested in results and how this turns out... I drive on the street and want to try the track settings for a couple track days, but make the change back to "street mode" for normal use and tire wear. Such a pita having aligned, realigned, etc. Thanks for sharing.
dlct3 is offline   Reply With Quote
