Old 05-16-2018, 09:33 AM   #1
11bravoss
Drives: 2018 ZL1
Whipple and dsx aux......
Hello everyone. I posted a while back about running a whipple along with the dsx aux fuel system and a few of you said your were running them them. Now I'm trying to figure out what pulley you went with on the whipple? My current set up is a cam, headers, ati dampener with a 9.17 pjlley(15% od) so I'm trying to see how small of a pulley I can go with.
11bravoss is offline   Reply With Quote
Old 05-16-2018, 11:06 AM   #2
rjacobs
Drives: none
you will still run out of injector...
After the low side(DSX kit) and the high side(cam with fuel lobe) the injectors are next to run out.
If you havent bought the DSX kit or the whipple yet I would strongly suggest you check out the Weapon-X port injection setup. Because once you buy the DSX kit AND the +30% injectors you will be right at the same place price point wise. And the Weapon-X kit, I believe, would give you a TON of more head room over +30 injectors and the DSX low side kit.
Just my opinion only.
rjacobs is offline   Reply With Quote
Old 05-16-2018, 12:06 PM   #3
scooter k
Drives: ex-wife's car
I'm running a 3" upper along with the 9.17" lower. I have meth injection with the DSX low side. Just got mine started and just started tuning. No clue how much boost it will make yet. Weapon X said a 3" and 9.17 lower would just about max out the blower rpm. That was my reasoning for using that pulley.
scooter k is offline   Reply With Quote
Old 05-23-2018, 09:46 PM   #4
11bravoss
Drives: 2018 ZL1
Thank you. Keep me updated please.
Old 05-23-2018, 10:17 PM   #5
kttxz06
kttxz06's Avatar
Drives: '18 Zl1. '18 GT350.
I'd run a 100-150 shot plate system on a sep fuel cell. That's my next mod, then I'm done. Should put me at 1000 hp.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
kttxz06 is offline   Reply With Quote
Old 05-24-2018, 10:12 AM   #6
scooter k
So far just over 17psi. My heads are ported so that lowers mine some.
Old 05-24-2018, 10:38 PM   #7
kttxz06
kttxz06's Avatar
We basically almost have the same mods. I'm upper/lower/meth/e85/headers/exhaust/NX lid/ported blower/snout/head work.
I'm at 803/768 right now. Just did my pulls two days ago in 95 degree heat so. I'm happy. Was hoping for over 850. I'll hit that once Sept/Oct runs around. My eth content was 47% too so. I'm gonna drain the tank, and refill with E85 then retune.
Thing is, manifold temps are thru the roof, pulling timing, we pulled it up to 190 degrees on the manifold temp side. IAT's are good, stay around 110 on hard pulls. Coolant temps since I have the Weapon X HX system stay around 180ish. Not sure why the manifold temps are thru the roof, but anyhow.
Whipple will just create more heat, so I'm staying with what I got and gonna run a NOS plate system on sep fuel cell and call it a day.
Old 05-24-2018, 10:46 PM   #8
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
Whipple will create less heat at same boost level due to larger displacement.
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 05-24-2018, 10:52 PM   #9
kttxz06
kttxz06's Avatar
But we won't have it the same boost level so. For my set up with controlling my heat issue, Whipple won't solve my problems. Until I can figure out why manifold temps are so high, then it's focus on more cooling, cooling, and cooling. I think the Ice tank and blocks will help out big time.
Old 05-25-2018, 04:58 PM   #10
scooter k
My IATs have been fairly low. I have the Weapon X heat exchanger with trunk reservoir. It might be different though once it gets really hot.
