Old 05-15-2018, 01:20 PM   #1
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3
10 Speed swap?
Just wondering if anyone has looked into this?
Seems likely to bolt in as the ZL1/LT4 bolt pattern is the same and there is no clearance/fitment differences that I'm aware of
I'd assume you'd need the trans, BH, converter, wiring and TCU and then a flash... Has anyone done it yet or looked into it?
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW
'22 Kia EV6 First Edition
'12 E93 M3
'25 911 (ordered)
Formers...
'18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 05-16-2018, 07:44 AM   #2
crosive
Drives: 18 zl1
I'm curious as well. Especially after given some time and some 2019's start showing up in junkyards.
crosive is offline   Reply With Quote
Old 05-16-2018, 02:22 PM   #3
RideZX6R
RideZX6R's Avatar
Don't need to wait - I'm sure there's some ZL1s there already
'12 E93 M3
'25 911 (ordered)
Formers...
Old 05-16-2018, 02:52 PM   #4
crosive
Drives: 18 zl1
this is true, and honestly, I'd rather have that 10 speed. I worry about the programming differences however, given the boosted application. the 10l80 *should* be very similar programming, from ss to ss.
I've found several wrecked zl1's in junkyards, but they are proud of them, understandably so.
Old 05-16-2018, 04:14 PM   #5
DFW1LE
DFW1LE's Avatar
I've been interested in this as well, but have been waiting to see someone here do it and the costs. I doubt the programming would be much of an issue.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 05-16-2018, 09:46 PM   #6
Drsagacity
Drsagacity's Avatar
Following too...
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 05-16-2018, 10:49 PM   #7
laynlo15
Drives: 2022 Lt1 A10
Trade for a 19 or Zl1. Cost will be prohibitive
Old 05-16-2018, 11:53 PM   #8
RideZX6R
RideZX6R's Avatar
Nope... Looking for a specific chassis/trans/engine combo
'12 E93 M3
'25 911 (ordered)
Formers...
Old 05-17-2018, 07:16 AM   #9
DFW1LE
DFW1LE's Avatar
The cost to trade in is not favorable. I would hope such an upgrade could be done for $7500 or less.
Old 05-17-2018, 07:19 AM   #10
Nsxmatt
Drives: 2017 Camaro
Going to be hard to find an answer seeing as there is very little benefit over the 8 speed so not many would waste the money.
Nsxmatt is offline   Reply With Quote
Old 05-17-2018, 07:43 AM   #11
DFW1LE
DFW1LE's Avatar
Not if your car is an M6 1LE that already has eLSD. If I was going to convert it definitely would not be for an a8.
Old 05-17-2018, 07:59 AM   #12
Nsxmatt
Drives: 2017 Camaro
All the wiring is integrated into the engine, chassis, and dash harness. The PCM and TCM, cluster, immobilizer, keys, all would have to be changed and reprogrammed, driveshaft, mounts, all different. Making a ZL1 trans work with a SS pcm, cluster, and all wiring along with the rear end which would need a custom tune on top of it, all that is next to impossible unless you have a complete donor car.
The people that are saying just trade the car are saying it for a reason.
Old 05-17-2018, 08:38 AM   #13
62nalide
62nalide's Avatar
Drives: 2013 SS
That would be a nice swap to do, cost may be some what high for the overall performance you may get out of it. New from GM $6500.00 plus labor and wiring harness (ZL1) that $$ could be used on performance mods. I'm sure you can find some used out of a wrecked ZL1 or SUV
62nalide is offline   Reply With Quote
Old 05-17-2018, 11:37 AM   #14
RideZX6R
RideZX6R's Avatar
Now you're getting it.
Lightest chassis with the best transmission
Where are you getting this info? The rear end is the same as an SS 1LE, so I see no issue there (for me, maybe not others)
'12 E93 M3
'25 911 (ordered)
Formers...
