Old 05-15-2018, 07:15 AM   #1
Drsagacity
Drsagacity's Avatar
LT Headers on the Vert?
Has anyone installed LT Headers on a vert? Any issues? Brand recommendations?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 05-15-2018, 09:54 AM   #2
drfeelgood
drfeelgood's Avatar
Drives: 2017 ZL1 Convertible A10
Why would there be any issues? The bracing on the vert that affects the exhaust doesn’t cause a problem accept at the rear where the final X is.
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq)
'17 Maserati Levante- STOCK
drfeelgood is offline   Reply With Quote
Old 05-16-2018, 09:38 AM   #3
Drsagacity
Drsagacity's Avatar
Yep. I see some setups are just primaries. Others are primaries, cats and all the way back to the axleback. I was trying to figure out if it was going to be problematic because of the additional bracing on the convertible. As an example, the stainlessworks headers specifically say they are not compatible with the convertible.
TBD performance
Old 05-17-2018, 03:24 AM   #4
drfeelgood
drfeelgood's Avatar
Yep. I see some setups are just primaries. Others are primaries, cats and all the way back to the axleback. I was trying to figure out if it was going to be problematic because of the additional support.
I have the Borla full catback with OEM headers, retained primary and secondary cats, it fits.
I have heard that the Kooks LT headers fit as well but can not verify
Old 05-17-2018, 12:32 PM   #5
Drsagacity
Drsagacity's Avatar
The stainlessworks headers specifically say they aren’t compatible, but I am thinking primaries would be no problem...as that would replace the stock manifold. Replacing the cats with high flow cats should be no problem. After that, however, it gets unclear.
TBD performance
Old 05-17-2018, 01:25 PM   #6
drfeelgood
drfeelgood's Avatar
exactly!
Old 05-17-2018, 09:40 PM   #7
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
Mine is going in as soon as my headers arrive. I have ordered Kooks 1-7/8ths headers and their mid/x pipe that will go into the factory NPP for now. Kooks specifically said that the mid pipe will fit the vert and it replaces the crush pipe. We'll see when it gets here
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 05-18-2018, 05:29 PM   #8
drfeelgood
drfeelgood's Avatar
yes, please take pics under the car, to compare with mine. especially near the rear cross section
Old 05-20-2018, 12:07 PM   #9
Drsagacity
Drsagacity's Avatar
I did get a quote for kooks with the ceramic coated cats. Trying to figure out if I get thisnwith the pistons and cam, or hold off till next round.
TBD performance
Old 05-20-2018, 06:26 PM   #10
Ricco
Ricco's Avatar
You are doing pistons and cam but still running the stock manifolds? Headers are usually one of the first mods, almost always before tearing into the engine.
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Old 05-20-2018, 06:54 PM   #11
mbnwa
Drives: 18 NGM ZL1 1LE
I will be doing TSP 1 7/8 next week with X pipe
PRIOR CAR:
17' Camaro 2SS A8 Vert Upgrades: Pray MSD IM/95mm TB/E85/Tune / Roto-fab CAI / GM Dark Taillights / LED Turn's with VLED Resisters / LED Reverse Lights / JWM Side Markers / Factory UQT PDR (CTS-V) / BMR DSL, MM010 / TSP 1 7/8 / Front Camera / Eyebrow Harness / Elite Engineering E2-X / AEM Wideband with Aeroforce single pod / HD Radio / OnStar Delete / RPM Roll Bar
mbnwa is offline   Reply With Quote
Old 05-20-2018, 07:01 PM   #12
Drsagacity
Drsagacity's Avatar
Yep. I know. I am debating doing them at the same time. I have always added headers with the supercharger. I know the stock manifolds run up to about 700rwhp pretty well. It’s just a timing thing.
As of now, I am getting cam and pistons to go in with fuel system (sitting at home). I will probably leave boost low until after summer...then I will add the headers and up the boost.
I really want pistons and crank seal replaced ASAP...doing the cam is just a freebie when you are in that deep. For this summer, Adding e85 and the 8-9psi pulley, I should be around 650rwhp. Adding the cam is only so I can get the fuel into the engine. Truthfully, I would hold off on the cam too, but I really want the pistons installed before Adding any more power.
TBD performance
Old 05-20-2018, 07:08 PM   #13
Drsagacity
Drsagacity's Avatar
I like the TSP prices...but I am trusting Ted and the team. Looks like they recommended Kooks headers with ceramic coated cats.
Btw - looks like they recommend 2in headers, not the smaller 1 7/8 headers. So will be doing that too.
TBD performance
Old 05-20-2018, 08:58 PM   #14
drfeelgood
drfeelgood's Avatar
There are fitment issues with the 2". Kooks says they will fit, but everyone is showing that there are rubbing issues. See the thread in the ZL1 page. Also, there's very little to be gained from going from 1 7/8 vs 2, so given the rubbing issues (which are well documented, even if Kooks won't admit to it), most of us running or considering kooks are going with the 1 7/8.
