Old 05-12-2018, 03:39 PM   #1
TDS
TDS's Avatar
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10
ZL1 2" Kooks Headers-Driver side rubbing
Anyone have 2" Kooks installed on there car that can confirm the fitment is good. I knew they would be tight but in a hard right hand corner with throttle the driver side header is rubbing the side. Took me several test drives to figure that out by the way! Had a vibration and for the life of me could not find it. The headers were installed by a shop over the winter and last weekend was the first time this year I could take the car for some spirted driving in the country. I but the car in the air and disconnected the connection pipes to make sure they were not torqueing on the engine. Actually made it worse, with the connection pipes off there was less then a 1/16 inch gape between the header and left side. I will call Kooks on Monday but in the mean time I was wanting to know if this is a on going problem. I have had Kooks on the last 3 cars with Zero issue. Hope they stand be hide there product. There warranty on there web site says they take back defective product with a RMA# and the buyer has to pay shipping. That does not seem right to me. What about labor? Knda hard to see in the pictures but you can see were the paint is rubbed off.
Name:  Kooks Header Rubbing 1.jpg
Name:  Kooks Header Rubbing 2.jpg
Name:  Kooks Header Rubbing 3.jpg
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats
Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer
TDS is offline   Reply With Quote
Old 05-12-2018, 03:52 PM   #2
ssrallyred
ssrallyred's Avatar
Drives: 2017 Summit White ZL1 M6
I have 1 7/8 Kook's. I installed them myself. The driver side was a VERY tight fit going in but its been 6 months now and no problems. I called Kook's before I ordered mine and they said unless you were going to be north of a 1000 rwhp the 2 inch wouldn't really make much difference. Hell as tight as the 1 7/8 were I don't if I could have got them to go in lol
Roto Fab/ Kook's LT's,ported blower,removed lid baffle/ 103mm TB' lower pulley and tune.
651/660.
ssrallyred is offline   Reply With Quote
Old 05-12-2018, 06:06 PM   #3
chicagosam
chicagosam's Avatar
Drives: 2017 BLACK ZL1 A10
Ill take a look at my 2" Kooks install this weekend.
From your pics, I cant see the rubbing. Can you circle the section in one of the pics and repost - I will look at mine.
'17 Mosaic ZL1 Katech TB, Plugs/Wires, Rotofab Oiled,+18% Lower, 2" Headers, Cat Delete, 93 Tune, Mobil 1, IPA FF04, 315/30/20 r888r, 664hp/693tq (93), 702hp/727tq (100 oct)
chicagosam is offline   Reply With Quote
Old 05-12-2018, 06:07 PM   #4
TheElementalCashew
TheElementalCashew's Avatar
Drives: 2017 ZL1
2” Kooks here, no rubbing.
2017 Camaro ZL1, Nightfall Gray Metallic: M6, PDR, exposed CF, navigation, sunroof
Mods: Rotofab CAI, Tony Mamo TB, Kooks headers (green cats), 18% LPE lower pulley, E85/FlexFuel sensor. BC Forged RS41s (19x10, 19x12)/PS4S, R888R (305/325)
Dyno: E40: 661whp/703wtq, 93: 633whp/674wtq
TheElementalCashew is offline   Reply With Quote
Old 05-12-2018, 06:11 PM   #5
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Looks like a solid reason to go to poly or solid motor mounts to me.
Old 05-12-2018, 06:59 PM   #6
TDS
TDS's Avatar
The shadow on the left side of the circle is actually the tube.
You can see a hole in the frame wall and just the front of that you can see were the paint has rubbed off
Name:  Kooks Header Rubbing 1_LI.jpg
Travis
Old 05-12-2018, 07:30 PM   #7
rjacobs
Drives: none
I would "persuade" both the sheet metal and the header tube JUST a fraction each with a hammer. Im talking a tiny bit each. Let both have some love. You will lose zero power.
rjacobs is offline   Reply With Quote
Old 05-13-2018, 11:47 AM   #8
zackf80m
Drives: Camaro ZL1
Having a similar issue, the header is actually rubbing on the steering rack. Same symptoms when making a hard right turn!
zackf80m is offline   Reply With Quote
Old 05-13-2018, 12:50 PM   #9
TDS
TDS's Avatar
I just went and looked at mine. It is also hitting the steering shaft. This picture is with the tires straight. So when I turn right those melt marks are right against the header and that the white mark on the header tube is melted plastic. Not cool! The melt marks prove one thing, they do not rub under hard straight line acceleration which means the body has a ton flex in it. Might be time to try the BRM strut tower brace. Maybe that would take out just enough flex to make them not rub. Defiantly calling Kook on Monday.
Name:  Steering Column _LI.jpg
Travis
Old 05-13-2018, 12:55 PM   #10
Well known issue with Kooks and the LT4
Old 05-13-2018, 01:24 PM   #11
TDS
TDS's Avatar
Well known issue with these and the LT4
Which part?
Travis
Old 05-13-2018, 02:02 PM   #12
Which part?
I thought we were talking about Kooks headers hitting the steering shaft.
Here's one example
https://www.camaro6.com/forums/showp...6&postcount=49
Old 05-13-2018, 02:14 PM   #13
TDS
TDS's Avatar
I did know if you were talking about that or the frame
Travis
Old 05-13-2018, 02:24 PM   #14
drfeelgood
drfeelgood's Avatar
Drives: 2017 ZL1 Convertible A10
thank for the info. This makes header choice a little clearer now.
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq)
'17 Maserati Levante- STOCK
drfeelgood is offline   Reply With Quote
