Old 05-08-2018, 08:35 PM   #1
Jmechler192
Drives: Summit White 2017 Camaro SS 1LE
Transmission Fluid Flush?
When I bought the car it was recommended that I have the transmission fluid flushed sometime around 20,000 miles. I'm currently at 19,500 and want to know what y'all think. Should I have it flushed or not?
Jmechler192 is offline   Reply With Quote
Old 05-08-2018, 09:59 PM   #2
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
According to the Owners Manual, manual transmission fluid should be changed every 45,000 miles. Page 341 in the 2017 version.
Old 05-09-2018, 08:17 AM   #3
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Also, if you're tracking the car at all, there's guidelines for how many hours of track use you're supposed to change fluid after. IIRC, my paper copy of the manual that came with my 2017 said 10 hrs in the Track and Competitive Driving section on p204, and the 2018 online manual says 15 hrs on p199.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 05-09-2018, 08:24 AM   #4
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
I have 14k miles on my car, and I've changed the transmission fluid 2x. I've found that gearchanges get a bit notchy after lots of track time. The fluid that came out of my trans both times looked like new, but shift feel was immediatly noticably better with fresh fluid.
I've driven student SS 1LE's on track as well that felt really notchy (doubt they had been changed yet).
Provoste is offline   Reply With Quote
Old 05-09-2018, 09:33 AM   #5
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
The transmission fluid is doing triple-duty in these cars. It a) lubricates the transmission, b) cools the transmission, and c) cools the differential.
Definitely a good idea to change fluid regularly...and you guys hit all the right notes:
-- If used on track: Change after 10-15 hours
-- If not: Change after 45,000 miles.
Old 05-09-2018, 01:18 PM   #6
trackjunkie61
Drives: 2017 1LE
What tranny fluid is recommended?
trackjunkie61 is offline   Reply With Quote
Old 05-09-2018, 01:46 PM   #7
6spdhyperblue
Drives: 2SS 1LE
ATF
Old 05-09-2018, 01:57 PM   #8
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Royal purple Syncromax. is what I put in mine. felt a difference when I swapped out fluids. Then again, I'm at 4300 miles in the 2 years I owend it. Not a 1LE, but the same transmission.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 05-09-2018, 04:49 PM   #9
Jmechler192
Thank you!
Old 09-27-2019, 09:19 PM   #10
GooseSS
Drives: 2018 Camaro SS
What sealant (if any) did you use when putting the 6MT plugs back on?
GooseSS is offline   Reply With Quote
Old 09-28-2019, 05:53 AM   #11
DorkMissile
DorkMissile's Avatar
Drives: DZ
My experience with my car is that it took probably 10k miles for the trans to feel decent when it shifted, I think it just took that long to break in.
I changed the fluid to RP SyncroMax at 2500 miles and it was a little better, but at 12k I switched to Amsoil ATF which was even better IMO.
DorkMissile is offline   Reply With Quote
