05-04-2018, 11:27 AM | #1 |
Drives: 2018 Zl1 Camaro Join Date: Feb 2018
RotoFab Install
Do you have to disconnect the battery for this install? I did the TM TB install and no need to disconnect it for that, so I figured it would not be necessary for this either, but wanted to check first. Thanks
05-04-2018, 12:36 PM | #2 |
Drives: '17 ZL1 Join Date: Jan 2018
Nope
05-04-2018, 01:12 PM | #3 |
Thanks
05-04-2018, 02:39 PM | #4 |
But you should. Anytime dealing with electrical components you should disconnect battery, takes 1 minute.
05-04-2018, 02:58 PM | #5 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
The directions say to disconnect. Takes like 30 seconds. I would to reset the computer to more quickly adjust the fuel trims.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
05-04-2018, 03:42 PM | #6 |
Drives: 2017 ZL1,2013 ZR1, 1952 C3100 Resto Join Date: Jun 2017
Just FYI........When we unplugged maf it threw a code on start up. Cleared it and all was fine
2017 ZL1,Mosaic Black, auto,nav/pdr, Roto Fab,Mamo
2013 ZR1 60th Anniv. 1952 C3100 resto-rod. LS6, 4L60e, 228R cam |
05-05-2018, 01:38 PM | #7 |
I completed the install this morning. I did not disconnect the battery, nor unplug the MAF, I actually unscrewed the entire MAF housing from the air tube (2 screws) and tucked it away until the new tube was on the car, then just screwed the MAF/housing back on. Entire install took me about 45 min start to finish, including cleaning under the hood. Threw no codes, runs great and definitely smoothed out the rough idle caused by the TM Throttle Body I installed. I didn't notice any difference with just the TB, but coupled with the RotoFab.... you can certainly tell the difference.
05-05-2018, 02:00 PM | #8 |
Drives: Zl1 Join Date: Feb 2017
I've been a tech for 30 years it's good practice to disconnect battery whenever you do any sort of wrenching on a car.
05-05-2018, 02:04 PM | #9 |
My only complaint is I wish the hose clamps were black instead of silver.
05-05-2018, 05:07 PM | #10 |
Installed my dry filter Roto-fab an hour ago. Didn’t disconnect the battery and test drove it after. Zero codes, lights or problems. To be honest, didn’t notice one bit of difference in sound. (Not testing power yet until 500 miles)
05-05-2018, 07:03 PM | #11 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
You’ll probably have to get into boost to notice the difference in sound.
05-05-2018, 08:12 PM | #12 | |
I love crepes
Also, as others have said the instructions recommend disconnecting the battery. I'm not sure why people don't want to take this quick and simple step. If it said open hood, would you skip that step too? I disconnecting when installing mine. |
05-06-2018, 01:51 AM | #13 |
Drives: 2018 ZL1 Join Date: Feb 2018
Past Rides 13 Porsche 911 4S 17 BMW M4 16 Shelby GT 350 07 Saleen Mustang 02 M3 Comp Pack 79 Corvette |
05-27-2018, 08:27 PM | #14 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Going to go rotofab for my Zl1...
What is the difference between oiled and dry? What would you recommend? Tx |
