Old 05-04-2018, 05:33 AM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Another oil thread...0w-40 Dexos 2 for street & track?
O.K...yawn, another oil thread. On Corvetteforum, the Z06 guys are spouting the new standard is Mobil 1 0w-40 ESP (Dexos 2) for the LT4 and the factory fill. Do ZL1s follow with this logic or does the dry sump of the Z06 make the oil choice solely for the Vette crowd? I will continue with the Valvoline 5w40 MST Dexos 2 but will switch if anyone knows. Thanks.
Old 05-04-2018, 07:31 AM   #2
Cameltow-ing
Cameltow-ing's Avatar
Drives: 2017 ZL1 A10 Red Hot
ck out this post on the ZL1 Exclusive site posted by a Joshua Jackowski on 4/26/18 at 08:20am
Cameltow-ing is offline   Reply With Quote
Old 05-04-2018, 07:48 AM   #3
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Shared this info in a previous post
driven2exceSS is offline   Reply With Quote
Old 05-04-2018, 07:49 AM   #4
Aliveguy5
Drives: 2017 Red Hot ZL1
I know this isn't what you asked but for information purposes only I figured I'd share. After all the oil vids/discussions that came out I switched to Amsoil 5W50 due to it being the only oil certified to not cause the carbon buildup that makes are cars blow smoke when at WOT due to our GDI. Mine used to blow out the smoke after minimal miles using the 5w30 Mobil that came from the factory, it now no longer does and truly runs much smoother.
Aliveguy5 is offline   Reply With Quote
Old 05-04-2018, 11:27 AM   #5
Stephen12ZL1
Drives: '21 ZLE A10
Thanks for the information. I will stick with Valvoline MST 5w-40 for the simple reason it was readily available at the local NAPA on sale for 5.79qt.
Old 05-04-2018, 12:36 PM   #6
wirebender
wirebender's Avatar
Drives: 2017 ZL1, A10, White, sunroof, nav
I had the service dept. at my dealership call GM service tech for clarification and there has been no change to the manual (track events and competitive driving section still applies) according to them.... so 0W-40, etc. is recommended for TRACK EVENTS/COMPETITIVE DRIVING ONLY! Not street use.
wirebender is offline   Reply With Quote
Old 05-04-2018, 12:51 PM   #7
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Good stuff. This is what I run too.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 05-04-2018, 01:32 PM   #8
Stephen12ZL1
Drives: '21 ZLE A10
Uh, the GM document above contradicts what was "told" to the service tech. I will take a document over service tech BS.
Old 05-04-2018, 03:00 PM   #9
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Running the 40 weight on the street will not hurt a thing, perhaps a tad less miles per gallon but I doubt you would notice the difference.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 05-04-2018, 03:05 PM   #10
wirebender
wirebender's Avatar
Doesn't that just refer to availability of the 0W-40?
Sure would like to get a definitive, reliable answer/decision on this.....
Old 05-04-2018, 07:23 PM   #11
DangerZL1
Drives: 2023 Black ZL1 Auto
I read this on the Corvette forum too. The new recommended oil will be the 0W40 ESP.
Old 05-04-2018, 07:36 PM   #12
Stephen12ZL1
Drives: '21 ZLE A10
It states "the recommended oil is..." That is definitive IMHO.
Old 05-04-2018, 07:49 PM   #13
EMTNLSS
EMTNLSS's Avatar
Drives: 2016 Hyper Blue 2SS
https://www.camaro6.com/forums/showthread.php?t=522484 I made a thread about it here. There's a PDF in there about it.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune
Upcoming Mods:
EMTNLSS is offline   Reply With Quote
Old 05-05-2018, 05:43 AM   #14
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Mobil is running a $17 rebate right now too...
https://mobiloil.com/en/promotion/mo...r-oil-may-2018
