Old 05-03-2018, 10:24 PM   #1
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
PDR Component part numbers and install
Considering adding PDR to a non-PDR car? regardless of what GM or your dealership says - it can and has been done.
The cost to add the PDR at purchase of the vehicle was about $1400; installing PDR after purchase will cost more unless luck is on your side. Parts will need to be purchased, and some will need replaced with components out of a PDR donor vehicle or purchased new. As more of these cars get totaled out and parted used parts are becoming available.
Cost of parts only to install PDR is around $2100 with a used recorder, camera and display.
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 05-04-2018, 07:22 AM   #2
Nitro66215
Nitro66215's Avatar
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV
Wiring harness might need modifying / creating. I've found that if the car wasn't optioned with it, the wires don't exist. Not sure on the PDR... but it is the case on several other options.
2018 2SS Vert - Hot Wheels - Indy 500 #30
2017 ZL1 Vert - M6 , SIM, CFW, NAV
2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-(
Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 -
Heads-Up Display - DIY
2011 CTS-V - Black / Black - SOLD. :-(
2013 ZL1 - Black / Black - SOLD. :-(
2010 2SS - Indy 500 Pace Car. - SOLD. :-(
2002 Z28 - Pewter / Black - SOLD. :-(
Nitro66215 is offline   Reply With Quote
Old 05-04-2018, 07:27 AM   #3
Nitro66215
Nitro66215's Avatar
Here's some of those diagrams
Old 05-04-2018, 08:11 AM   #4
nighttowl
nighttowl's Avatar
the wires are on my list to find the numbers for.
my Nav unit was already updated with the PDR, it may be plug and play - I dont know. I emailed gen5diy about what else is needed, but they havent gotten back to me yet.
the dash has 2 different part numbers for with / without PDR. im not sure where the recorder actually sits - it may just be the difference of the SD card slot. if its just the SD card slot - im going to cut it. if the recorder mount area is not in my dash Ill have to change it.
I dont want to change the dash - but a mans got to do what a mans got to do; right???
Old 05-04-2018, 08:14 AM   #5
Nitro66215
Nitro66215's Avatar
Totally understand. I'm adding HUD to mine. So far have the top and front parts of the dash ordered. Waiting on all parts to come in before taking those dash covers apart. I'm hoping that the bracketry is at least the same regardless of HUD option. I'd hate to have to modify the framing of the dash to mount the HUD.
Old 05-04-2018, 08:42 AM   #6
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Does the instrument panel also include the SD card socket?
You'll also need the PDR-specific windshield. It appears to be 84133729. Given only HUD cars are able to have PDR, it appears logically correct.
Old 05-04-2018, 08:46 AM   #7
nighttowl
nighttowl's Avatar
The instrument panel does have the socket.
Old 05-05-2018, 04:12 PM   #8
nighttowl
nighttowl's Avatar
I went to the dealership today to get some help from the parts guy.
I cannot find any diagrams online for any of this stuff.
I was able to buy the recorder bracket, recorder antenna, short recorder harness and the SD Card receptacle. Total for these was $390 from the dealer, so Im in near $1500 at this point, not including the money I spent to buy the navigation I added to the vehicle from gen5diy.
Based on what I was told, the Dash harness is different on the PDR cars; the PDR wiring is integrated into the harness.
Old 05-05-2018, 05:17 PM   #9
Nitro66215
Nitro66215's Avatar
I posted diagrams a few posts above. Part numbers to wire terminals are in there. You'd have to add wiring to the harness.
Old 05-05-2018, 07:40 PM   #10
nighttowl
nighttowl's Avatar
I meant parts diagram on the parts website so I can see what I was buying, and how it went together.
I did look at and appreciate your help with the attachments you posted.
Ive attached the recorder connector images. on one end it has a greay and black connector, which ive bought the short harness (84030546) and on the other end it has the recorder antenna and 3 micros usb ports. the camera just has one micro usb as well.
based on your file, the black connector must be for the camera, and clearly the SD Card reader must plug into one of the others. maybe the extra one is left un-used but the diagram the dealer gave me shows harness number 7 using all the ports.
I guess Ill know more when I pull the covers off the dash next weekend after the recorder and other parts arrive.
Old 05-06-2018, 01:06 PM   #11
mbnwa
Drives: 18 NGM ZL1 1LE
Hello, I am looking to do the same upgrade on my Camaro, do you know if the parts list is different on the convertible? I assume most of the parts will be the same but the camera mounting might be different, I cannot seem to locate any real documentation on the parts list for the PDR outside of the above.
Here are a few items I was able to find:
Vehicle Performance Data Recorder Malfunction:
Display Malfunction
 1. Ignition OFF, disconnect the X1 harness connector at the K161 Performance Data Recorder.
 2. Test for less than 10 Ω between the ground circuit terminal 12 and ground.
⇒ If 10 Ω or greater
2.1. Ignition OFF.
2.2. Test for less than 2 Ω in the ground circuit end to end.
⇒ If 2 Ω or greater, repair the open/high resistance in the circuit.
⇒ If less than 2 Ω, repair the open/high resistance in the ground connection.
⇓ If less than 10 Ω
 3. Verify that a test lamp illuminates between the B+ circuit terminal 1 and ground.
⇒ If the test lamp does not illuminate
3.1. Ignition OFF, remove the test lamp.
3.2. Test for less than 2 Ω in the B+ circuit end to end.
⇓ If the test lamp illuminates
 4. Ignition OFF, connect X1 harness connector at the K161 Performance Data Recorder.
 5. Disconnect the X2 harness connector at the K161 Performance Data Recorder.
 6. Ignition ON.
 7. Test for less than 1 V between the signal circuit terminal 6 and ground.
⇒ If 1 V or greater
7.1. Ignition OFF, disconnect the X1 harness connector at the A11 Radio. Ignition ON.
7.2. Test for less than 1 V between the signal circuit and ground.
⇒ If 1 V or greater, repair the short to voltage in the circuit.
⇒ If less than 1 V, replace the A11 Radio.
⇓ If less than 1 V
 8. Test for less than 2 Ω in the signal circuit end to end.
⇒ If 2 Ω or greater
Repair the open/high resistance in the circuit.
⇓ If less than 2 Ω
 9. Test for less than 1 V between the signal circuit terminal 12 and ground.
⇒ If 1 V or greater
9.1. Ignition OFF, disconnect the X1 harness connector at the A11 Radio. Ignition ON.
9.2. Test for less than 1 V between the signal circuit and ground.
⇓ If less than 1 V
10. Test for less than 2 Ω in the signal circuit end to end.
⇒ If 2 Ω or greater
⇓ If less than 2 Ω
11. Connect X2 harness connector at the K161 Performance Data Recorder.
12. Verify the three USB cables are properly connected at all components and there is no damage to the cable or connections.
⇒ If connection problems or cable damage is noted.
Perform the appropriate repair or replacement to correct any issues.
⇓ If no connection problems or cable damage is noted.
13. Ignition OFF, connect the EL-50334-50 to the P17 Info Display Module connector X5 and the performance data recorder connector X3.
14. Ignition ON, performance data recorder system ON.
15. Verify the performance data recorder system operates properly.
⇒ If performance data recorder system does not operate properly
15.1. Replace the P17 Info Display Module.
15.2. Verify the performance data recorder system operates properly.
Replace the K161 Performance Data Recorder.
⇓ If performance data recorder system operates properly
All OK
16. Replace the USB harness.
Record Malfunction
 1. Ignition OFF, disconnect the X2 harness connector at the X20 Memory Card Receptacle.
 2. Test for less than 10 Ω between the ground circuit terminal 4 and ground.
2.1. Ignition OFF.
⇓ If less than 10 Ω
 3. Verify that a test lamp illuminates between the B+ circuit terminal 6 and ground.
 4. Connect the X2 harness connector at the X20 Memory Card Receptacle.
 5. Verify the USB cable is properly connected at all components and in-line connections, and there is no damage to the cable or connections.
 6. Connect the EL-50334-50 to the memory card receptacle connector X1 and the performance data recorder connector X5.
 7. Ignition ON, performance data recorder system ON.
 8. Verify the memory card receptacle operates properly while operating the performance data recorder system.
⇒ If memory card receptacle does not operate properly
8.1. Replace the X20 Memory Card Receptacle.
8.2. Verify the memory card receptacle operates properly while operating the performance data recorder system.
⇓ If memory card receptacle operates properly
All OK
 9. Replace the USB harness.
mbnwa is offline   Reply With Quote
Old 05-06-2018, 01:13 PM   #12
mbnwa
Attached is a few images / diagrams I was able to locate for the PDR.
The PDF Vehicle Performance Recorder Wiring Diagram might be of interest to all looking to do this.
Old 05-07-2018, 03:01 PM   #13
Nitro66215
Nitro66215's Avatar
I'm still trying to figure out why the PDR option wasn't available for the Convertibles. I don't see anything so far that would eliminate it from the verts.
Old 05-07-2018, 03:02 PM   #14
mbnwa
I just ordered all the parts guess we will find out shortly I know they offered it on the Vert Corvette, as I owned one in the past. Any additional info anyone finds out would be great and I will post back any of my updates after all my parts come in. I did get the PDR out of a CTS-V so fingers crossed it should be the same one it's a different part number vs what was listed above.
