Old 05-03-2018, 08:39 PM   #1
Drsagacity
Drsagacity's Avatar
Which spare tire setup are you using?
I switched from runflats to non-runflats.
I am looking at this sort of kit: https://modernspare.com/product/2016...ncluding-case/
What are you using for your vert?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 05-03-2018, 10:30 PM   #2
Corvette_Mike
Corvette_Mike's Avatar
Drives: 2018 Camaro SS
I have a 2018 SS with run flats. I am thinking about buying a spare tire. Don't like the thought of driving on long trips with no spare. New Good year eagle F1's run flats are over $2k. When these are done thinking about buying non run flats for $1k and buying a spare tire.
Corvette_Mike is offline   Reply With Quote
Old 05-03-2018, 10:51 PM   #3
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Why not just get a puncture repair kit and an electric pump.
WhiteNight is offline   Reply With Quote
Old 05-04-2018, 07:57 AM   #4
Drsagacity
Drsagacity's Avatar
That’s a possibility too. It just doesn’t guarantee I can fix the tire. Further, I am concerned about the potential damage to my car should I need to be towed.
Which kit did you get?
TBD performance
Old 05-04-2018, 09:23 AM   #5
JoeGSr
Drives: 2017 LS Convertible
Where do you keep this in the car when the top is down? Backseat?
JoeGSr is offline   Reply With Quote
Old 05-04-2018, 11:51 AM   #6
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
I have the one that is sold in every auto store. It has the sticky wormy things, round file, and a tool to push the worm in the hole
As for inflator, check on Amazon. A lot of good inexpensive units with good reviews.
Old 05-04-2018, 11:58 PM   #7
Drsagacity
Drsagacity's Avatar
Don’t know. I was hoping someone on the forum already had an answer...besides staying on runflat tires, since that is a dealbreaker for me. They can’t handle any more power than stock.
TBD performance
Old 05-05-2018, 12:52 AM   #8
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
A flatbed tow truck.
ninetres is offline   Reply With Quote
Old 05-05-2018, 07:01 AM   #9
Drsagacity
Drsagacity's Avatar
I can only imagine getting the car off a trailer would be really bad for my front chin splitter. But yes, a flatbed was my first thought.
TBD performance
Old 05-05-2018, 06:58 PM   #10
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
I still have the Goodyear Run-Flat tires. Regardless, I still carry what I need to attempt to repair a puncture.
I would use the plug kit first, but if that does not work, I have the sealant kit as a back up. The sealant kit includes an inflator.
The sealant kit comes in a pouch that fits neatly under the trunk floor in the large rectangular opening in the foam structure. I keep the plug kit in a box that also fits under the trunk floor.
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 05-07-2018, 09:09 PM   #11
Skeeter
skeeter
Drives: 2018 Camaro ZL1, A10
Run Flat vs. Non-Run Flat
I have a 2017 Convertible SS. I recently replaced the F1's (with 3,000 miles on them) with a set of Michelin Sport 4S. I felt the F1 tire was to rigid. I bought a very good 12V compressor, a can of fix-a-flat, and a plug kit that also comes with a CO2 inflator. I love the Michelin's. Burt just to be on the safe side I'm also a member of AAA.
Skeeter is offline   Reply With Quote
Old 05-07-2018, 09:39 PM   #12
Drsagacity
Drsagacity's Avatar
I just bought the setup from modern spare.
I will see how it fits in the trunk. I may get the fix a flat stuff in case I am cruising around town and if going further, will throw the modern spare in the car.
TBD performance
Old 05-07-2018, 09:46 PM   #13
Chevyman2
Chevyman2's Avatar
Drives: 2018 zl1
I ordered spare last month still waiting on delivery was told mid month this month. What shipping date were you told?
Chevyman2 is offline   Reply With Quote
Old 05-08-2018, 06:58 AM   #14
Drsagacity
Drsagacity's Avatar
I haven't seen a shipping date yet. I will ping them today just to get an idea. Will post when I get a response.
TBD performance
