![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
BAP and e85
I am buying my components to round out phase 2 of my Wicked SS transformation, otherwise known as #projectundertheradar...
Phase 1. Magnuson running 7-8 psi Phase 2: Upgrade fuel system and move to 9-10psi Phase 3: forged pistons and rough idle cam (winter) I have ordered the components for the fuel system upgrade, but in doing so I decided to also add the e85 sensor. Here’s the question, should I use a Boost-a-Pump with e85? It was included with the first round of products for running 93oct. - lt4 hpfp - lt4 in tank pump - lt4 injectors - spark plugs - BAP - HP Tuners Pro version (not standard) - 90mm pulley and belt - dual gauges (boost and afr) Secondary New adds: - e85 kit - front crank seal - Crank case breather It occurred to me, I don’t think I have ever seen anyone using the BAP with e85, but truthfully, it’s not something I looked for because I wasn’t planning to go down that route. Tell me what you know...
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance Last edited by Drsagacity; 05-03-2018 at 04:04 PM. |
#2 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
You will be limited how much E you can run with the stock cam lobe and all the LT-4 components. I really like having a flex fuel sensor on board as the computer will know the actual alcohol content and give you the best all around running engine. Crank Case breather not oil pressure release valve. ![]() Thank you for your business. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#3 | |
#projectundertheradar continues...
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#4 | |
I guess I could try to run e85 with the 95mm pulley instead. At 7-8psi on 93, we saw the 550-560rwhp. What would that mean on e85? I suppose that’s ok, maybe I really don’t use the e85 until the next phase with cam and pistons?
#5 | |
![]() Drives: 16 Camaro 2SS Join Date: Feb 2017
You can typically run up to E-50
#7 |
![]() Drives: Camaro Join Date: Mar 2016
Not trying to take over the thread but I've got a similar build going with a Whipple. From what I understand, it sounds like its the low pressure fuel pump that is running out before the high side.
Would adding an auxiliary low side fuel pump (from DSX Tuning/Weapon X, CPR etc) add enough fuel to run E85 or will the high side still run out without a cam lobe? I haven't been able to find a good answer what an auxiliary fuel pump setup will support by itself without major high side upgrades. |
#8 |
Ted,
Would that be the case even staying with the 95mm pulley? I was planning on the 90mm pulley for 93...could I get similar results just running e85 with the 95? After I add the pulley, then could I run e85?
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance Last edited by Drsagacity; 05-05-2018 at 12:25 AM. |
#9 | |
With your Real name, vehicle info, complete mod list I can better answer specific questions. So I will give a general answer that should help everyone. You must have our complete fuel system upgrade package to run anything past 10% ethanol fuel on a supercharged application along with one of our Flex fuel sensor kits and our custom tuning for that. The boost level will dictate What E-% you can run. I viewed a log yesterday on a Whipple Gen3 system with 3.625 pulley or about 8 psi boost and he had E-58% and still had a little head room on injector pulse, the fuel pressures both low and high were holding strong. Each combo will react differently so I recommend we creep up on it by starting with a mix that I will recommend, and watching logs to see where the threshold is for that combo. Ted.
#10 | |
![]() Drives: 2016 Camaro 2SS Join Date: Sep 2016
#11 | |
I have experienced just that seems like there is not much gain after E-60 at this boost level but at higher boost levels that changes to more gains for more E. You will never get pure E-85 at the pump it seems it is roughly E-65 -E75, I think the gas stations cheat by ordering too much 87 and dump what doesn't fit in the 87 tank in the E tanks. Ted.
