![]() Drives: 2018 1SS 1LE Join Date: Apr 2018
285 vs 305 on a 10" wheel
I can't decide between a 285/35/19 front and 305/30/19 rear or 305 square RE71R for my autocross setup. I'm staying in AS so the 10" front wheel is the issue. I believe using the tire that fits the wheel (285) is the best choice, however, this car is heavy and a 305 does fit but not optimal.
2018 Summit White 1SS 1LE, PDR, Black Bow Ties
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE Join Date: Mar 2016
The turn in with the 305s up front is AMAZING, and I haven't noticed any adverse affects of having the slightly too big tires on the 10" wides. I say go with the 305s, you won't regret it!
IG: @NC_M1SS1LE
#3 | |
I’m going to slap them on MRR M716s with the track alignment. Are you running tpms sensors? I thought about just putting in regular valve stems, but thought against it if I travel for an event.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i have a 275/30/20 on my 20x10 works just fine or a 285 would be fine also which is oem 1le size
#5 | |
IG: @NC_M1SS1LE
![]() Drives: 71 Camaro '18 1LE Join Date: Feb 2016
I have the same setup with TPMS.
First time I had to use fire to seat a bead, so that was fun.
Donny
#7 |
![]() Drives: Arctic Blue '18 1SS 1LE Join Date: Oct 2017
I am also thinking about that same wheel/tire setup but with the offset being 23 mm up front with a shorter wheel how much camber are you getting. Are you using a spacer and if so what size. Thanks
