05-03-2018, 07:05 AM | #1 |
Drives: Black Join Date: Jan 2017
2019 gm v8 truck specs released
http://gmauthority.com/blog/2018/04/...ings-revealed/
As many of you know the current l86 motor has the same long block as the lt1. All the internals, head, cam, valvetrain are all part number for part number identical. Not sure if this trend will continue with the new trucks. But the specs were leaked regardless. L86 (‘14-‘18)= 460ft lbs, 420hp L87 (‘19+) = 450ftlbs, 425hp. Afm now allows multiple configurations and it will even run on 1 cylinder now, and have start stop. |
05-03-2018, 08:27 AM | #2 |
Chevy & Ford Enthusiast
Drives: '21 Camaro LT1 Join Date: Jul 2015
I think i'm one of the few who actually love the new Silverado. Surprised they went down in torque on the 6.2L and no change on the 5.3L.
05-03-2018, 08:33 AM | #3 |
I used to be Dragoneye...
I'm with you. I'm a really big fan.
05-03-2018, 08:51 AM | #4 |
looks much better then the 2019 Camaro.
2016 NFG 1SS A8
05-03-2018, 01:09 PM | #5 |
Drives: SS 6 speed of course Join Date: Jan 2016
05-03-2018, 02:05 PM | #6 |
Well.. if that's your benchmark
05-03-2018, 02:55 PM | #7 |
Nope it's not. I prefer the looks of the 17-18 Silverado over the 19. Just saying the 2019 truck refresh is the least offensive of the 2.
2016 NFG 1SS A8
05-03-2018, 04:35 PM | #8 |
Pizza & Wings Only $12.99
Drives: 2017 Camaro SS Join Date: Jan 2012
One cylinder. Interesting...
Basically a Silverado powered at times with a weed wacker.
H-Town Camaro Club
Past Rides: 2012 Camaro 2SS/RS M6 2012 Camaro ZL1 A6 2017 Camaro 2SS M6 |
05-03-2018, 04:54 PM | #9 | |
That said...they can shut cylinders down with a single cycle...basically saving fuel one squirt at a time! |
05-04-2018, 12:06 AM | #10 |
no fuel is saved by afm in the silverado. 4cly is not enough to maintain speed
05-04-2018, 05:12 AM | #11 |
Flat road, when all the trans, diff, and transfer case fluids are up to temp (takes a solid 20-30minutes), I’m cruising in v4 getting 22-23mpg at 75mph, done it numerous times for long distances.
05-04-2018, 05:32 AM | #12 |
Drives: Love the one you're with Join Date: Sep 2009
Drop torque in a pickup. Boy the hits just keep coming. Im sure you have to get the top model to get the 6.2 again which is crap. Does anyone have pics of the GMC version?
05-04-2018, 09:45 AM | #13 |
2016 NFG 1SS A8
05-04-2018, 10:35 AM | #14 |
btw, google laura GMC if anybody is interested in one
cheapest and highest volume dealer in the country Loaded slt crew cab with the 6.2 you can usually pickup for $40-$42k. |
