![]() Drives: 16' 2SS, 06' Silverado SS Join Date: Jul 2017
Run Flats -Can they be plugged?
quick question
can the stock run flats be plugged in the event of a nail in the tire? so far ive had all four tires replaced from nails with the rear being recently. of course, again, another nail. its hardly leaking air maybe 3psi a day. is it possible to plug it for the time being? I figured it couldn't but I thought it was worth an ask. |
![]() ![]() ![]() Drives: 2021 Tesla Model 3 LR Join Date: May 2016
It depends on where the nail is. Close to the side wall? Needs replacement. Towards the middle of the tire? Can be plugged.
![]() Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
If NOT tracking the car, I would Plug it!!
![]() Drives: 2017 50th Anniversary Join Date: Dec 2015
They CANNOT be "PLUGGED" they can be Patched. Patching a tire requires that it be removed from the rim and the repair done from the inside.
I had a nail in the rear tire at about 1600 miles. Only place that would touch it was a Good year dealer. |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Had min plugged last summer. No issues.
#7 |
I had a nail puncture repaired that was in the center of the tire just like the OPS. I chose to have the tire dismounted and patched. That worked great. Got another 2500 miles out of the tire before replacement time with zero issues. I'd go patch over plug.
#8 | |
luckily I saved a front tire and it happens to be the same tire so im just getting that mounted for the time being for 23 bucks. much better than buying a new one let alone two. and with the replacement 2500 miles afterwards, that was just due to the natural wear? |
#9 | |
#10 |
![]() Drives: 2017 50th Camaro SS Join Date: Jul 2016
Really? Where did you read that? I had 3 separate run flats on the car at the same time, all with plugs in them and never had an issue. Maybe cause I do my own work.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
#11 |
![]() Drives: 2017 2lt rs Join Date: May 2017
Cost up here is 45 bucks .make sure they have the right machine to dismount and Mount
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
Do you have discount tire there? They patched mine for free.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Plugged a nail hole in mine good old fashion way last year. Been fine
Ream it out a bit by hand. Shove the goo and glue in and pull it out. Done |
#14 |
![]() Drives: 2017 Camaro 2SS Convertible Join Date: Sep 2017
I plugged mine on the side of the road. Tough getting plug in. The run flat is thick. Rasped it a couple times. Then plugged it. 2000 miles ago. Hasn’t leaked a drop. I’ve hit 120 several times. No problems. I wouldn’t push past that just for safety concerns. I have 11,000 miles on original run flats. Plan on going a couple thousand more and then going to non run flats.
Plug that sucker and get some money out of that tire first. |
