Old 04-30-2018, 11:55 AM   #1
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Transmission hesitating
I have the A8 transmission.
This morning I slowed down & stopped at a light. A few seconds later the light turned green & I stepped on the gas, but the transmission wouldn't engage; the car just sat there. after about 5 seconds of that, it started engaging & the car started moving. This is the first time that's ever happened.
Any thoughts?
classicrockr is offline   Reply With Quote
Old 05-01-2018, 10:01 AM   #2
awrj2000
Drives: 2016 2SS Camaro
Low fluid, check for leaks.
I would say check fluid level, but that is a true PITA...
Maybe change fluid and filter. Key here being plugged filter (read they trap anything larger than 70 micron).
If it was just one time, it may not be anything. Consistent....usually means problem will get worse over time.
awrj2000 is offline   Reply With Quote
