Old 04-29-2018, 05:14 PM   #1
Bigdome77
Drives: 2018 Camaro SS 1LE
Track Day Helmets
Hello All,
I have a dilemma in picking a helmet for track days. I have a 2018 SS 1LE and I am not a small guy...about 6'1". Seems all the helmets I have tried rub on the roof of the car and the headrest. Are there low profile helmets out there that are still certified and will be allowed at track days? Also are those Recaro Headrests adjustable beyond up and down, or will I need to just remove it for the day.
So far Shoei is my top runner, fits the best and has the smallest size/ lowest weight. Unfortunately it is really expensive.
Bigdome77 is offline   Reply With Quote
Old 04-29-2018, 05:24 PM   #2
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
I don’t know if they are any “thinner”, but you need to purchase a “SA2015” rated helmet, which is designed for car racing. I don’t know that Shoei makes any SA helmets, I think they only make motorcycle cycle helmets. Just google “SA2015 helmet”. Most legit sanctioned tracks will require a SA-rated helmet, some may accept the SA2010 rating.
blazzin1 is offline   Reply With Quote
Old 04-29-2018, 08:11 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
SA2010 is good until 01/01/2022. No "some" about it.
Old 04-29-2018, 08:22 PM   #4
blazzin1
blazzin1's Avatar
You may be right about that. I just know that SA2015 is the most current rating, and SA2010 was the previous rating.
Old 04-30-2018, 01:02 PM   #5
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
Originally Posted by Bigdome77 View Post
Hello All,
Please, find a track shop and go try on several models. They all fit VERY differently. Even ones that are the same size and model (closed face, SA2015, etc.) will be different. Some squeeze your cheeks more, some allow glasses, etc.
You can likely find a circle track, drag race, or similar shop near you. If not, call a local track and ask them. I probably tried on 7-8 different helmets at Clausen Racing (here in Louisiana) before deciding on one.
00 Trans Ram is offline   Reply With Quote
Old 04-30-2018, 01:09 PM   #6
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Hello All,
Do you have the seat adjusted all the way down? I clear fine with SA2015 helmet @ 6'0" I think if you are wearing some of the Motorcycle helmets they are a little taller and don't fit as well.
Old 04-30-2018, 01:18 PM   #7
Whitespeed
Drives: 2018 1SS 1LE & 1973 Datsun 240Z
I'm 6'7" and fit fine with a helmet. Mind you, my height is biased towards my legs, with a 38" inseam. I also tend to sit a a fairly reclined position, which helps a fair bit too. Hopefully you're not a T-Rex and can recline the seat more Lol! But I understand that a comfortable seating position is subjective.
Nigel
Whitespeed is offline   Reply With Quote
