Old 04-28-2018, 10:11 PM   #1
Goohead
Horsepower whisperer
Drives: Camaro
P228c
Can grade if gas cause a P228c code?
Decreased engine performance is defined as a Fuel Pressure Regulator 1 Exceeded Control Limits - Pressure Too Low
I currently running a stick Whipple tune, I use she’ll gas religiously but had a recent fill up on Sunoco 93 and on a WOT pull got this CEL, have not had this problem before
Also what is normal fuel pressure range? Logged from HP tuners
Goohead is offline   Reply With Quote
Old 05-03-2018, 01:19 AM   #2
Goohead
Drives: Camaro
Anyone?
Old 05-03-2018, 04:51 AM   #3
laynlo15
Drives: 2022 Lt1 A10
Sounds like your running out of fuel to me. Your fuel pressure at wot should be around 2100 to 2200.
Old 05-03-2018, 06:49 AM   #4
Drsagacity
Drsagacity's Avatar
Sorry, what are you running? I don’t see your setup anywhere.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 05-03-2018, 06:57 AM   #5
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
get a datalog of a wot pull and we can tell you exactly what's wrong. the last time i had that same CEL; i had 40% ethanol mixed in the tank and the car ran out of high pressure fuel.
the datalog will tell you exactly where the problem is
best of luck; before putting the car into limp mode again; find out what exactly the problem is and address it
hitmix300 is offline   Reply With Quote
Old 05-03-2018, 07:05 AM   #6
shinysun
Drives: 2016 Camaro SS
If you use the tune from Whipple, check the desired fuel pressure. It usually makes the trouble. I had the same issue.
shinysun is offline   Reply With Quote
Old 05-05-2018, 05:02 PM   #7
Goohead
Drives: Camaro
attached log, please take a look at the short wot bursts, stock whipple calibration
https://www.dropbox.com/s/sucdf9irak9qft9/code.hpl?dl=0
Old 05-05-2018, 09:21 PM   #8
shinysun
As I told you, adjust the target fuel rail pressute. From 20Mpa to 15Mpa on top. Simply change it to the stock table.
20Mpa is over spec for LT1 high pump.
Old 05-06-2018, 09:01 PM   #9
Goohead
Drives: Camaro
What hp tuner pid are y’all using for fuel pressure, logging fuel rail presssure get a rating between ~40-80psi
Old 05-06-2018, 10:14 PM   #10
shinysun
That is the low side. Check the high side pressure.
Old 05-09-2018, 08:09 PM   #11
Goohead
Drives: Camaro
What’s the pid name for it?
Old 05-09-2018, 08:26 PM   #12
shinysun
Fuel rail pressure
Old 05-09-2018, 09:58 PM   #13
Epx998
|Engineer|
Epx998's Avatar
I watch that one, so about 2100-2000 it should be at?
2016 Camaro SS A8 | Magnuson Heartbeat | Might Mouse Wild Catch Can | DSX Flex Fuel | Eibach Pro Kit | Flowmaster Outlaw Black Series | MRR 017 Wheels
Epx998 is offline   Reply With Quote
