Old 04-27-2018, 03:41 PM   #1
zfuzz
zfuzz's Avatar
Drives: 69 Z28 / 12 ZL1
ZL1 1LE Brake lines
Does the ZL1 1LE come with upgraded brake lines for the track or do they need to be replaced?
zfuzz is offline   Reply With Quote
Old 04-27-2018, 04:18 PM   #2
wstaab
Drives: 69 Z28, 2018 ZL1 1LE
Standard OEM rubber brake lines.
Goodridge now has a set available with the correct brackets for the front lines.
Goodridge USA 12299 G-STOP SS Braided Brake Line Kit
Available through Amazon:
https://www.amazon.com/Goodridge-122...oodridge+12299
wstaab is offline   Reply With Quote
Old 04-27-2018, 09:47 PM   #3
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Appreciate the tip. Thanks.
2018 ZL1 1LE sw/PDR
Old 04-27-2018, 11:12 PM   #4
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I haven't really found the car needs them yet. Have you?
seanblurr is offline   Reply With Quote
Old 04-28-2018, 01:21 AM   #5
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
Or these beautiful brake lines.. I was also wondering if they needed upgraded?
https://www.renickperformance.com/co...brake-line-kit
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 04-28-2018, 01:56 AM   #6
waterman
waterman's Avatar
Absolutely true, not needed...yet.
Heat, pressure, ethylene compounds and rubber (as I am sure that you are well aware, no slight intended) are not the best of friends. Braided lines are just a great insurance policy for protection against the combination of the potential for abrasion, chemical degradation and radiant heat from hard braking under track/race conditions.
It would be an awesome addition to the 1LE option.
My humble opinion.
2018 ZL1 1LE sw/PDR
Old 04-28-2018, 02:01 AM   #7
waterman
waterman's Avatar
Those Renicks are very sexy!
2018 ZL1 1LE sw/PDR
Old 04-28-2018, 03:13 AM   #8
nicktechla
nicktechla's Avatar
yeaaaah... i was thinking about next time i do a brake fluid flush
IG: 2fast2nick
-- Current --
-- Past --
Old 04-28-2018, 08:28 AM   #9
rjacobs
Drives: none
The Renick's are a little cheaper from Weapon-X.
I cant bring myself to like the Goodridge lines. I had a bad experience with them years ago. I also dont like an un-coated line, which the goodridge, unless you special order them, appear to be.
rjacobs is offline   Reply With Quote
Old 04-28-2018, 11:14 AM   #10
OminouSS
OminouSS's Avatar
Drives: Red Hot track candy
SS lines on this car really are more aesthetics. I've heated the fronts to turn the calipers from silver to gold in one long TT. Never lost pressure. The braided are not essential. In fact, I bought a second set of OEM lines as spares and never had to use them. But yeah, it makes you feel good and look even better so move the finger closer to that hair trigger.
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
OminouSS is offline   Reply With Quote
Old 04-30-2018, 04:19 PM   #11
zfuzz
zfuzz's Avatar
Thanks guys for all of the replies, love those Renicks !
Old 04-30-2018, 10:57 PM   #12
Spurshot
Drives: 2014 2SS blue
I bet if you cut an OEM line, you’ll see braided steel inside.
Spurshot is offline   Reply With Quote
Old 04-30-2018, 11:08 PM   #13
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Both. LOL
"Standard" braided lines, covered in rubber. Cut one in half.
Old 05-01-2018, 10:50 AM   #14
Badgerbimmer
Badgerbimmer's Avatar
Drives: ZL1 A10
Sounds great until some track debris cuts a line.......
My rides:
2017 Camaro ZL1 A10
2015 Jeep Grand Cherokee Diesel
2012 Audi S4
1992 Porsche America Roadster
1990 BMW 325Ic
Badgerbimmer is offline   Reply With Quote
