![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
MBRP race system with kooks headers and no cats
The MBRP race system fit up perfectly to my kooks headers and off road connection pipes.
Sounds really good. Drone is 85% gone so I’m happy. Can still detect very little around 1500 rpm but it’s not bad at all. It really does a good job Anyway thought I’d re confirm what a couple others told me. If you have kooks headers with connection pipes the mbrp race will bolt right up to it. So one can have a nice full exhaust system and no drone. |
That's good to know, I'm considering some Kooks "offroad" headers plus extension pipes and I run an MBRP axle back.
2017 Camaro 1SS - Bright Yellow - 6spd
You still have the stock x pipe if you just have the axleback. You’ll need to cut the stock exhaust if you get headers
Pics
vidz please!
I’ll see what I can do bro
#7 |
The MBRP systems have always been an under rated system. They sound great and really took care of the drone issues with their J-pipes. We highly recommend them for anyone considering an exhaust.
#8 |
#9 |
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
Can also check out my videos, having it cammed sounds AMAZING!!!!!!
https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
#10 |
Sounds great!
I’ll be doing heads cam at some point. Have you got any new accurate numbers yet? |
#11 |
Nope not yet, my 160 degree thermostat took a crap on me, so switched back to stock on that, hardly drive the car and with work i get quite busy with schedule changing and traveling.. BUT BUT BUT if i can find either a dyno day in town or a shop that has availability to dyno the car then i'm all up for it because my current tuners dyno just isnt' cutting it, at least reads 30+ difference from any other dyno. :( i'm assuming i'm around 550 to the wheel, maybe more??
#12 | |
I’ve read literature advising against 160 tstats in some newer motors. Something about excessive wear due to incomplete expansion in the motor. Guessing ring seal. From being too cold. |
#13 | |
but all is well, now for the REAL build to start
#14 |
