Old 04-26-2018, 07:33 AM   #1
Est98SS
Drives: 2016 Camaro 2SS M6
How to wire 2 step to clutch?
I recently setup a 2 step/launch control which can be activated via 12v connection. I’d like to set it up to a clutch switch so that it’ll only go off when the clutch is fully depressed however I do not know which wire to tap into. Any ideas? At the top of the clutch I found these three wires.
Est98SS is offline   Reply With Quote
Old 04-26-2018, 07:47 AM   #2
Nitro66215
Nitro66215's Avatar
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV
This might be what you are looking for.
Top image is the B25B Clutch Pedal Position Sensor
2018 2SS Vert - Hot Wheels - Indy 500 #30 - SOLD
2017 ZL1 Vert - M6 , SIM, CFW, NAV - SOLD
2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-(
Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 -
Heads-Up Display - DIY
2011 CTS-V - Black / Black - SOLD. :-(
2013 ZL1 - Black / Black - SOLD. :-(
2010 2SS - Indy 500 Pace Car. - SOLD. :-(
2002 Z28 - Pewter / Black - SOLD. :-(
Nitro66215 is offline   Reply With Quote
Old 04-28-2018, 08:04 PM   #3
Est98SS
Thanks for he diagrams, was able to get it done by tapping the yellow wire however the 2 step has to be switched off when starting the car or it won’t recognize that the clutch is pushed in, not sure if there’s another way around it.
Old 09-11-2019, 07:55 AM   #4
i4bumblebee
Drives: 2017 Camaro 2SS
Did you have to cut the yellow wire to connect it or were you able to just tap it in the wire
i4bumblebee is offline   Reply With Quote
