Old 04-23-2018, 09:35 PM   #1
ScratchAce
ScratchAce's Avatar
Drives: 2SS - Hyper Blue/Ceramic White
Tubes hang too low?
I recently had 1 7/8 headers with 3" long tubes installed. I'm a little concerned with how low the tubes hang. Near the middle of the car, they literally are 1" off the ground - I can't slide the width of a yardstick between the tube and the ground (see the pic). Granted my garage floor is a bit uneven, but trust me, even on a complete flat surface, there is 1-1.5 inches of clearance. This just seems to be installed a bit too low. The installer told me "that’s normal as the pipes go underneath everything and are now not crushed flat like the factory ones". Just looking for confirmation that 3" tubes should hang that low...
2SS - Hyper Blue/Ceramic White, A8, MRC, Npp, Sunroof, Low-Gloss Black Wheels, White Rally Stripes.
ScratchAce is offline   Reply With Quote
Old 04-23-2018, 10:03 PM   #2
Mullet_Machine
Drives: SRT4, 2ss
It looks like it was installed under the cross brace. It needs to go above it in the little "tunnel" the stock exhaust ran thru.
Mullet_Machine is offline   Reply With Quote
Old 04-23-2018, 10:53 PM   #3
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
This. I'd get it looked at soon, you're going to destroy those pipes if you have to go over a speed bump or big curb.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S
dotfiles is offline   Reply With Quote
Old 04-23-2018, 11:13 PM   #4
Juiced1
Drives: 2012 2SS CAMARO 45th
The crossover pipe might be flipped the wrong way. It's normal for long tubes to sit lower then the factory exhaust but an inch off the ground just won't work.
Juiced1 is offline   Reply With Quote
Old 04-24-2018, 12:34 AM   #5
IsaacLt1
Drives: 2016 camaro 2ss
Gonna take a guess you bought the system from speed engineering
IsaacLt1 is offline   Reply With Quote
